94 F350 giving me fits
#46
Usually, if you replace one, do them all. These are 20+ year old caps, and they have been subjected to extremes. Good that now as RLA mentioned, you are passing KOEO.
Lean code can be vacuum leaks, leaking exhaust, gasket leaks. The bogging down and hard shifting could be result of code 172, because it its not able to enrich the fuel mixture, thus not having the power when loading it down.
Either case, I would be inclined to check resistance if the TPS circuit, and clean the contacts of the TPS connector. If it's a no name brand, then try to get a Motorcraft TPS sensor when possible.
Also, if you haven't found the O2 sensor harness, that's the next step. If you look on the passenger side fenderwell, near the battery and close to the fender mounted relay, there should be a weatherpack connector that is white. It is the beginning of the O2 sensor harness that runs down the passenger side wheel well and then to the separate O2 sensor pigtail.
Good to know about replacing all the caps. If I have to take it back out I'll replace them all
Its never thrown the 172 until I fixed that cap. I don't know if its a coincidence or not? I'll work on the tps tomorrow while its warm out. Could the lean code be from a faulty tps combined with no o2?
I'll have to look for that weatherpack. I don't remember seeing anything over there but I wasn't really looking for it. It would be nice if its there.
Thanks for the help!
#47
I think I might have found the answer.
Theres that bunch of vacuum lines that go into the top of the intake. There was 3 that were blocked, so I removed the caps and re-installed the lines. The truck started a little funny, but caught itself. Now the truck seems to run great! And theres no CEL on anymore. This doesn't explain the TPS or EGR codes (I don't think) but its working.
I also tested the TPS and it seems to be ok.
I found that white plug on the passenger side inner fender for the o2. It seems to be capped off from the factory? Heres a pic:
#48
#49
I believe the closed value was 1v. Whatever changed helped tremendously.
I believe you about the o2, I just cant believe whoever got rid of it went through so much trouble to hide it.
#51
#52
I recall reading somewhere that the wiring assembly for the O2 may still be available. I would have called my parts guy if I had seen this post earlier, was asleep though, and didn't. But I would check eBay or call around to several well known junkyards, and ask them what's available. I have 2 huge junkyards within 50 miles, but they pull it, not you. But everytime I've called, they have the part.
Added.. I'll try tomorrow and see if he can locate it. If not, I'll let you know.
#53
Thanks for all the help guys! So far so good, the truck runs 100x better then before!
I'll dig around the yards around here and see if I can find a harness. Just to make sure, the F150s went to obd2 in 96 while the larger trucks stayed obd1 until the body style change? If I find an older F150 that's obd1 will the harness still work if the trucks a 5.0?
#55
#56
#57
Im in Northern MA on the coast. Most of these trucks rusted into the ground.
I drove the truck 24 miles today. For half the ride it was fine, but on the way back it reverted back to its old symptoms.
I got code 111 122 172 332 334
334 is a new one for me. I thought I read in a TPS write-up that sometime they can go a little crazy when they're bounced around. Maybe its a sign that its going bad?
#58
Just to give you guys an update....
I replaced the aftermarket TPS with a used Ford one. I then took the truck for a ride and hit some really choppy bumpy roads and the issue didn't come back. I wonder if the aftermarket one was right on the edge of what the computer is looking for, and when I hit rough roads it had an effect on the TPS?
Whatever the case may be the truck seems to be running nice now! I'll work on the o2 next.
#59
Mo8414
03-24-2023 08:51 PM
Tranz zam
11-04-2014 03:26 PM
fordboy5894
08-27-2010 07:32 PM
grass happens
1983 - 2012 Ranger & B-Series
03-30-2009 05:51 AM
