Ignition Key Switch Question
I feel a bit foolish about this, but I can not figure out how this works.
1989 F250 Std. Cab Lariat XLT Key actuator on steering column.
When you turn the key to start the truck what exactly causes the key to "spring back" to the run position?
I have gotten a new key actuator assembly but I do not see it "springing" back when it is released.
I have looked at photos of the ignition switch itself, but see nothing to cause the key to return to run automatically. What am I missing?
I can and do manually return the key to the "run" position, so it appears that all the internals work as expected except for the return issue.
Can someone explain to me how this works?
Thanks
TNCritter
Thanks
TNCritter
Received 3,101 Likes
on
Hey TJC
Thanks I am trying to correct the "return to run" spring issue
By the way, from another thread... I ordered a set of those wiper arms with the spray jets in the arm, I will post what I think about them after I receive them.
How hard is it to get to the spring in the column for the key "return to run"?
Is it a separate piece or is it part of the ignition switch connector?
Thanks
TNCritter
Thanks
TNCritter
on
gwhpnut
01-24-2018 10:37 PM
tmcalavy
12-29-2000 04:57 PM
