2001 f150 wont start at times.
The ignition switch powers up a lot of circuits.
It could be the ignition switch, the PCM relay or PATS.
The two major systems that need to be powered are the PATS and the computer.
A failure in any one of these three areas is a no start even though the starter circuit cranks the engine.
On the engine proper, if the front crank sensor plugup was intermittent there will be a no start as well.
Good luck.
Good luck.
TooColdCuzImSoHot
1997 - 2003 F150
02-16-2016 04:26 PM
bub80z28
04-07-2014 08:49 AM
exoldstar86it
12-03-2005 02:19 PM
