6.4 loss of power/shut off
While driving about 70 mph truck lost power, – instrument panel red pullover safe and then shut off would not start waited approximately 45 minutes disconnected both batteries reconnected now will crank but won't fire! Truck is completely bone stock 216,000 miles on it
Need help!!!
Need help!!!
No I just tried it that once.
No I don't have a code reader.
Yes I can hear the fuel pump.
About 4 days ago I change primary and secondary fuel filters when I did my oil change.
Two weeks ago get some water in the fuel had a drain separator.
Nothing unusual. Ran a little crappy. i'm just gonna have it towed home in about three hours when I get back up there it's about 22 miles from the house! So I can just work on it here, playing mechanic on the side of the road sucks and it's cold as hell outside! Haha
First check the fuel cutoff switch in the passenger side of the dash. Open the door and there is an access door. Reach in and make sure it is depressed. Try to start. Next I would pull the fuel filter and shine a light in the bowl and see what it looks like. Be sure to cycle the key once you put the filter back on.
Houston Cowgirl
03-24-2012 10:22 PM
roger 922
03-09-2008 06:10 PM
