Leaf
Yes you can take one out of the leaf spring pack. It will lower it not sure if it will make it level or not that depends how much of a rake your truck has. Keep in mind though it will decrease your load weight you can have in the bed if you use it for any hauling/towing. Are your front coil springs cut or worn out that it is raking to the front? Depending if you want the truck lower or higher maybe new front springs is a better option unless your after the lowered stance.
on
taking out one leaf wont hardly do jack-sheet. two or three would maybe get it down some, but it would still be raked. and then you just have a truck that cant carry a cooler without draggin.
the only way to get it level is to do the shackle mods in the rear, or lift the front($$$expensive$$$)
other than that, you just have to get used to it. i would love to lift mine up in the front a few inches, but there just is not an easy way like on the newer trucks.
68mustang
07-27-2006 08:34 AM
rebocardo
07-08-2004 11:05 PM
rickdog67
10-09-2003 04:11 PM
