Rear window wide chrome???
Old 01-07-2015, 07:16 PM
Penn79's Avatar
Penn79
Penn79 is offline
Question Rear window wide chrome???
Is there any special way to pop off the rear Chrome around the slider that is still on another truck? Or is it pretty straight forward?? Thx
Old 01-09-2015, 11:11 AM
Dcutlip74's Avatar
Dcutlip74
Dcutlip74 is offline
I removed mine with a small flat trim tool and sprayed silicone as I went. Installation is a bit trickier because over time it gets brittle and cracks easily. Hopes this helps!
Old 01-09-2015, 11:45 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
This is the late 1977 & 1978/79 version.
Welcome to FTE
OP has a 1976.
There are TWO different types of back glass mouldings. TWO different types of back glass weather strips.
1973/76 F100/350 - 1977 F100/350 before serial number O80,001:
D3TZ-1042430-A Right & D3TZ-1042431-A Left .. Back Glass Mouldings-Chrome Steel / Obsolete
D3TZ-1042084-C .. Back Glass Weather Strip / Reproduced
1977 F100/350 from serial number O80,001 - 1978/79 F100/350:
D7TZ-1042430-A .. Back Glass Flexible Chrome Plastic Moulding - 143" long - cut to fit / Reproduced
D7TZ-1042436-A .. Back Glass Joint Clip / Reproduced
D7TZ-1042084-A .. Back Glass Weather Strip-Use with one piece flexible chrome plastic moulding / Reproduced
scott79's Avatar
scott79
scott79 is offline
Not sure if this is what you are looking for but I would just purchase some new for $25. Here is a link for you!!
http://shop.broncograveyard.com/imag...wndwrvlset.jpg
Old 01-09-2015, 12:29 PM
NumberDummy
This is: D7TZ-1042430-A .. Flexible Chrome Plastic Back Glass Moulding (see post 3).
OP has a 1976. This moulding was used on 1977's from serial number O80,001 - 1978/79's.
Old 01-09-2015, 02:29 PM
rougeriver's Avatar
rougeriver
rougeriver is offline
I think this is the molding the OP is asking about. This truck is a '76 XLT and has bright trim around the side SC windows and the rear slider.
David
Old 01-10-2015, 01:37 PM
Penn79's Avatar
Penn79
Penn79 is offline
Yes thank you all for your replies and David yes that's the correct moulding I'm talking about. I Was able to get it off with some patience. Thx. Now I have to get it powder coated and put in back in.lol
Shane in WI
24
05-20-2016 08:40 PM
psquare7575
WTB - Parts & other
02-16-2016 06:42 PM
ryanf77
03-05-2015 02:25 PM
KermitTheMudTruck
07-13-2012 12:26 AM
4xfourdoorFloyd
01-21-2011 01:28 AM
Quick Reply: Rear window wide chrome???
