Which Tranny Fluid
Keep in mind if it matters to you that the Valvoline is not licensed by ford. Even the bottle states "ATF for Mercon V Applications" instead of "Valvoline Mercon V".
Valvoline.com > Products > Valvoline > Automatic Transmission Fluid Valvoline > ValvolineŽ ATF for MERCONŽ V applications
I use Castrol Transmax Mercon V, it can be found really reasonable at times.
how about Castrol Transmax Mercon V (ATF) Automatic Transmission Fluid?
Castrol Transmax Mercon V (ATF) Automatic Transmission Fluid (1 Quart) 06818: Advance Auto Parts
and what trans Filter? I need to change on my 2000 Excursion V10.
Thanks John
Thanks John
on
Here is Mark Kovalsky's recommended 4R100 fluid change instructions.
Changing ATF Fluid in a E4OD and 4R100 transmission - Ford Trucks
Even though he don't recommend changing the filter, I do it at about 100k to 120k just to check for sediment in the pan/magnet more than anything. The pan gasket is reusable, so try not to destroy it.
I've been using the Castrol Transmax in my 05' for the last few changes. Works well as far as I can tell...lol. I also use it in the transfer case.
on
Changed out or just changed? Also I agree, I would never drop the pan. That is a filter but it is large and efficient enough so it would never contaminate unless you had a full blown clutch failure, etc.
The thing is, how do we know that there is not multi-use fluid in that bottle? We've been told for years not to put multi-use in these transmissions. I'm not chancing it.
Thanks John
Thanks John
Castrol Mercon V Automatic Transmission Fluid is certified for use in Ford vehicles that require Mercon or Mercon V.
#30
