Coolant Questions
Good stuff here. I agree water is the best for heat transfer. Not the best though for corrosion protection. I also found the info about a 20% mixture being good down to 10*very useful. Central California rarely sees temps below 25* unless you are up in the mountains.
Would 20% give adequate corrosion protection? If so then I will begin using a20% ratio.
I was chasing a cooling issue in one of my other cars and drained the near 100% coolant the PO had used. I put pure water in and it still looked like a 50/50 mix color. I did this a couple times and it was still light green....never turned rusty even after sitting several years!! So a little goes a long way for corrosion.
This was in a pure iron system though - engines with aluminum heads/intakes might need closer monitoring and coolant isn't 100% efffective for corrosion protection - some folks go to extremes and use sacrificial anodes (usually a zinc "pendant" hanging in the radiator). But there is nothing that can truly prevent the electrolysis in an iron/aluminum system full of hot water-based coolant! The best you can do is change annually and monitor.
Back in the 90's, My brother lived in Novato and left his boat sitting in the street during an entire week when the temps didn't even get ABOVE 25 F!
He also didn't bother to drain the block......you can probably guess what happened.
I guess in my previous comment about heat transfer, I should have qualified it.................Water is NOT the best liquid for heat transfer in any automotive application.....Unless you live in the tropics! (and you don't care about corrosion!!)
Cheers,
Rick
I, however, live in FL, so it feels like the tropics most of the time...even here in N. Fla. We rarely get more than 4-6 hours of continuous temps below freezing on the odd 2-5 days/yr that it actually gets below freezing. But we do have our moments...last year, we actually got some snow, sleet, freezing rain and two whole days where the OAT didnt' get above 25*!! So pure water isn't a sure thing here either. Burned the fronds on my palm trees!
I've got somewhere between 25-30% in my truck right now...should be good for the cold we get, the lubrication needed in the system, and the anti-corrosion help.
having a "mix" also gives you boil protection too......
....so it helps on both ends....... (of the temp scale)
Boo_Daddy
10-29-2013 07:53 PM
