Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-20-2003, 10:12 PM
buschracer is starting off with a positive reputation.
will a power stroke fit
hello i wrote the thread on the truck not starting on its own! now that the engine is blown up, does any one now if a power stroke will fit in its place, i talked to a mechanic and he said that it would fit but there is alot of extra electrical sensors and stuff on that engine. so it would be hard to do!!! the truck that i want to put it in is a 1990 f-250 with an automatic-overdive. the blown engine is a 7.3 liter that had an ats turbo on it. has any one done this, and if so how big of a job was it and how much did it cost? or would i be better off trying to find another engine that the truck came with??? any response will be helpful!!!
thanks alot
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-20-2003, 11:37 PM
eiznekcm is starting off with a positive reputation.
Bushracer,
I am almost done putting a 98 Powerstroke in my 90 F-350 4x4. I have also put a 99 6-speed in place of the E4OD. It has been a real challenge. If you have a donor truck with EVERYTHING stll on it, it is possible. My Stroke is out of a 98 E-350(van) ambulance. The Motor mounts were different and my 7.3 IDI mounts were not tall enough to clear the oil cooler. I had to make spacers.
The Van turbo is different from the f- series turbos and I do not think it will fit without a body lift. I put a 3" body lift so I would have more room. If your donor is a n F-series truck it sould fit with no problems.
My flywheel was different than the newer one so I am not sure if the torque converter will bolt up.
I am now trying to figure out all of the wiring.
So far it has taken me 3 weeks of part time work to get this far, but I hope to have it done within 2-3 more days.
If you try it Good Luck, be patient, and be thorough checking out the wires.
E-mail me if you have any other questions.
Craig
__________________
90 F350 with 98.5Van Powerstroke+99 ZF6speed Tranny/Tcase Kwik'sOrifice,Hutch,Prepump,10K,CCVmods,Flatbed,35 " BFGs
Failure is the opportunity to begin again more intelligently.Henry Ford
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
