Transmission Swap Questions
Old 01-06-2015, 12:50 PM
Building_Fords's Avatar
Building_Fords
Building_Fords is offline
Hi all, now that I am getting ready to get under my Cab and start working the frame fuel, brake lines etc... I will probably work on the transmission as well. I currently have a C6, and am seriously considering switching it to an AOD 4 speed. Other then the transmission itself, what do I need to consider? I have done manuals before, they aren't that difficult, but I have never swapped an automatic.... I know I need to ensure I have the right Drive Shaft length, but I also have an Inline 6 300... will it bolt right up? What about the crossmember? (Both are automatic so I assume no change is needed.) Is there anything specific to a year or specific engine I need to consider? Any advice would be greatly apprecited.
Kelly Burleson
12-18-2014 09:13 AM
AbandonedBronco
1978 - 1996 Big Bronco
05-21-2013 02:38 PM
nstueve
05-14-2010 12:55 PM
84ford150
26
08-21-2008 01:09 PM
83pickemup
15
03-07-2003 04:09 AM
Quick Reply: Transmission Swap Questions
