Besides OEM and now Warn, what are our choices for replacement locking hubs? My F250 has 105,000 miles so I'm looking for options when mine need replacing.
Thanks
I called WARN in the hopes these Hub's would actually run "FREE" as stated on the Hub itself (Lock/Free) but it does NOT, they operate just as OE does.
So u still need to get a SpynTec conversion if u want an actual "free spin" Hub
Thanks
The only difference between OEM and Warn is the outside cover. Warn makes the OEM hubs with the Ford name.
Just tried to install a set , did not fit , 1/2 in gap . has anyone had a prob with this ? I called warn and they said that there are some that were made wrong .... any input ?
So quick recap, these hubs are a direct replacement and when in free they operate the same as auto for the factory hubs? I am looking at installing these in my 2020 f250.
