running 93 instead of 87 gasoline
Old 01-05-2015, 07:42 PM
gdoug219's Avatar
gdoug219
gdoug219 is offline
Does anyone think running 93 octane gasoline in my 14 3.7 L v6 F150 poses any problems for my trucks long term durability?
Thanks,
George
Old 01-06-2015, 04:51 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,217 Likes on 800 Posts
Won't hurt a thing but it's not necessary.
Old 01-06-2015, 07:25 AM
bakon's Avatar
bakon
bakon is offline
hurt your wallet only
Old 01-06-2015, 07:32 AM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
It will cost more. It will be a little harder to start in cold weather. Mileage may get worse. There is no upside in your case.
Old 01-06-2015, 10:10 AM
Frdtrkrul's Avatar
Frdtrkrul
Frdtrkrul is offline
Only thing that'll hurt is your wallet for the $0.30 or so per gallon more. If it was EcoBoost yeah it probably would be worth the extra fuel costs.
Old 02-01-2015, 07:14 PM
fishbones182's Avatar
fishbones182
fishbones182 is offline
If your engine is tuned for it run it otherwise run 87 and save a bit of cash.
Old 02-01-2015, 08:31 PM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
Excerpted from the 2014 F-150 owner's manual ...
3.7L V6, 5.0L V8 and 6.2L V8 Engines
Regular unleaded gasoline with a pump (R+M)/2 octane rating of 87 is recommended. Some stations offer fuels posted as Regular with an octane rating below 87, particularly in high altitude areas. Fuels with octane levels below 87 are not recommended.
Old 02-01-2015, 09:57 PM
Tom's Avatar
Tom
Tom is online now
Most modern engines adapt their ignition timing from the knock sensor. So you stand to gain some top-end power with high octane gas.
This was discussed briefly with Mike Harrison, the chief engineer for the 6.2L engine. Adrian, BigF350, used to be employed as an engineer for Ford as well and chipped in on this thread.
https://www.ford-trucks.com/forums/9...ml#post8833938
Old 02-02-2015, 06:10 PM
mrrish79's Avatar
mrrish79
mrrish79 is offline
That is a killer thread!
dzdiggin'dude
Modular V10 (6.8l)
02-12-2011 09:01 AM
rsylvstr
1997 - 2003 F150
01-25-2007 09:05 AM
78bigunns
02-10-2003 05:23 AM
gasman6674
12-21-2002 03:24 PM
baitboy
13
04-02-2001 11:18 AM
Quick Reply: running 93 instead of 87 gasoline
