flathead distributor installation
Newbie in need of some direction. I just got back a 239 flathead that I had rebuilt and need some assistance installing the distributor. Do I just align the timing pointer to the timing mark on the pulley and install the distributor with the rotor pointing at #1 on the distributor cap.
Yep, same as for any other engine (pretty much), but you have a 50-50 chance that without further checking, you are at TDC on the exhaust stroke. If you have the #1 plug out, you can crank it over with your thumb over the plug hole; when it blows your thumb off the hole, that's compression stroke TDC. You'll likely have to back it up a ways to get the marks aligned. By the way, the marks are actually at 3 deg BTDC, which is where the timing gets set at idle with the vacuum line disconnected.
rlh68050
08-17-2019 06:19 PM
dogmantra
10-04-2010 12:43 AM
btacarlton
28
04-17-2009 09:40 AM
ErrorS
11-07-2007 07:04 AM
Narwhal
04-19-2005 11:21 AM
