Wheels feel like they are wobbling off
Old 01-05-2015, 02:27 PM
gerk3's Avatar
gerk3
gerk3 is offline
OK, so let me start by saying that I hate starting new threads that seam to be covered, but I have a few issues that were not talked about.
I just installed my 2.5" leveling kit. The drivers side went really easy. The passenger side was VERY difficult getting the strut back in without a spring compressor. I got it though after some prying.
Now when I drive straight down the road, she does great. When I turn left, she does fine. When I turn right, it feels like the wheel is wobbling off.
Most of what I have read, people are having wobbles at 60+ MPH. Mine does this at any speed.
What did I do wrong? What is wrong with the truck? Does the leveling kit need to go? What can I do to fix this.
Extremely frustrated.
THANK YOU ALL for any help
Old 01-05-2015, 05:56 PM
wheelerfreak's Avatar
wheelerfreak
wheelerfreak is offline
Did you get it aligned after the lift?
Are the wheels mounted securely with all lug nuts torqued?
Are the tires balanced?
Check those first if it didn't do it prior to the lift.
Old 01-05-2015, 08:28 PM
danorules's Avatar
danorules
danorules is offline
Check your ball joints.....now
gerk3's Avatar
gerk3
gerk3 is offline
I did not. However the wobble seems bad enough that it wouldn't be the issue.
I had a leveling kit done on my '01 F250 and it had a slight shimmy at high speeds, but not like this.
As far as the lugs, when I first drove it, that is exactly what I thought, so I loosened up the lugs and retightened. Still the same.
The tires should be balanced, but again, all was smooth before the leveling kit
It can't hurt to do it again, but I don't think it is those things.
Old 01-05-2015, 08:30 PM
gerk3's Avatar
gerk3
gerk3 is offline
Can you be more specific on what I should do with the ball joints?
Old 01-05-2015, 09:13 PM
wheelerfreak
If you didn't get it aligned yet do that ASAP. By lifting it you jacked up your alignment. Your F250 had a solid front axle so wasn't affected as bad by a lift as an IFS truck would be.
Old 01-06-2015, 02:16 AM
gerk3's Avatar
gerk3
gerk3 is offline
OK, sounds like an alignment is next.
Let me ask this.
If I do the alignment now and it does not fix the problem, will I have to pay an alignment shop again when I throw away the leveling kit?
Old 01-06-2015, 04:57 AM
Sako 75's Avatar
Sako 75
Sako 75 is offline
Check your vacuum lines to the IWE's. Sounds like you have a hub engaged,
Old 01-06-2015, 09:33 AM
gerk3's Avatar
gerk3
gerk3 is offline
You know what? That is prob the best way to describe the feeling my truck has. Feels like 4wd is engaged. The feeling you get in the steering when you are popped into 4Wd and trying to make a sharp turn. I get that feeling at 40 mph(or any speed for that matter) and only slightly going around right corners. Scary when you are on a main road and not in a parking lot.
I will be checking that this morning when the sun comes up and I get her in the garage.
Old 01-06-2015, 11:40 AM
gerk3's Avatar
gerk3
gerk3 is offline
So I did a test and let me know if I did it wrong.
Lifted up each side and started up the truck.
If there was a vacuum leak, the front tires would spin the axle right.
When I did so, the tire rolled smoothly with no axle engagement telling me that the hub is not locked into gear.
If that is all, I guess I will go get her aligned. Unfortunately no shop is close to me.
Old 01-06-2015, 04:10 PM
gerk3's Avatar
gerk3
gerk3 is offline
Problem Solved
All fixed.
Alignment set for Thursday, but let me just say this to anyone doing this for the first time.
Put everything back in place in opposite order that it was taken off and torque every bolt properly.
Old 01-06-2015, 05:29 PM
danorules's Avatar
danorules
What was not tightened properly
Old 01-06-2015, 06:33 PM
gerk3's Avatar
gerk3
gerk3 is offline
With my tail between my legs, yes you guessed it.
That passenger side was a monumental pain in the butt to get the strut back in place and once I got it in, I was not thinking properly. I swear I tightened that steering link, but I only got it down part way. There was a 1" gap were it did not get tightened all the way down.
Thank you everyone for helping me
Old 01-07-2015, 06:01 AM
danorules's Avatar
danorules
That tie rod end should have a castle nut. That may be why it's backing off
robs01f250
09-09-2010 12:47 PM
kissingbug1978
2004 - 2008 F150
04-18-2009 03:21 PM
JAYMONEY
05-05-2008 10:47 PM
tank55
2004 - 2008 F150
07-03-2006 10:03 AM
rfairwea
1999 to 2016 Super Duty
05-01-2005 09:25 AM
Quick Reply: Wheels feel like they are wobbling off
