A no start thread
A no start thread
I need some help with my 96PSD. It up and died on me last summer while going down the road. I found right away fuse 22 was blown, but I didn't have a spare. Called for someone to drag me home. Once there I unhooked the fuelbowl heater and put in a new fuse. Well it blew immediately and a wisp of electrical smoke came up from the left front of the fuel bowl. Not right up by the bowl but from somewhere around in there. I wanted a better look at it so I got right up where I could see and put in another fuse. This time it didn't blow but now the engine won't start.
I do hear the injectors clicking, the glow plugs cycle on and off, and the tach shows when the engine is cranking. No smoke when cranking so apparently no fuel is being injected.
What could be the problem? I did make sure the HPOP reservoir was full. Would a HPOP gone bad cause a wire to smoke?
Agreed ^^
If the IPR wiring is melted or shorted, it could have been the source of the wisp of smoke you saw since the wiring goes down in the front of the fuel bowl to the IRP. The IPR is actually kind of buried down in there, but the wiring is part of the fuel bowl harness, and I've seen more than one IPR harness that was melted from a fuel leak that ate the wire insulation.
Thanks guys. Looks like I have a starting point. I read up on HPOP operation and it makes sense.
I did remove a high pressure line and cranked the engine over. I thought the flow was rather small and weak. If I read right, the IPR dumps oil to sump if it receives no power or ground signal. Is this correct?
Bowl heater isn't taped but it is hanging in mid air not grounded while I'm testing. But you made me think I should test it for power.
Using a test light it gets power when connected.
I tested the wire for the bowl heater and it isn't getting power. Does it run all the time or only below a certain temp?
RIFFRAFF FORD DIESEL PERFORMANCE PARTS
You can get an ipr pigtail from Clay ^^, or you could check ford, but they will probably have to order it too.
