Time for new ball joints.
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
i would do everything at once and use XRF ball joints
Brake pads, rotors, hubs, upper and lower ball joints, u-joints, you can clean and grease your existing hubs or replace if they are in really bad shape (mucho expensive) id go with warn if you have to replace. Haha this list could go on and on if your ball joints are bad probably could do all your tie rod ends as well, i did all this when i first got my truck i also threw in a new steering box too, the peace of mind from all new was great and not to mention the steering was much tighter and handling much improved.
I just started getting a squeak. I think its my left lower ball joint. I really don't want to do this job myself at least right now.. as it was -5 degrees out when I woke up today. I have been quoted 3 hrs a side labor to do lower and upper and new u joints. My ford mechanic said.. ball joints, u joints and axel seal, dust shield, knuckle seal. her eis a good link to the parts. https://www.ford-trucks.com/forums/1...4-vs-05-a.html
So has anyone here had bad luck with moog? I see most recommend xrf.
Thanks for the link.
Thanks for all the replies.
Another reason for not using XRF is their ball joint page on their website. I quote,
"If you've got a $5.00 family, then by all means use $5.00 all joints".
To this I say, "XXXX (starts with F, ends with K) YOU!!!!
Show me your American factory with American workers and I will pay.
XRF Chassis | Automotive and Heavy Duty Chassis Parts | Ball Joints
Uuuhhh I don't know where you're hearing all this bad information about XRF ball joints but from my personal experience they performed MUCH better than the Raybestos I replaced.
This was a 2004 Dodge RAM 2500 Diesel. I replaced the balljoints when I bought it with Raybestos and 15000 miles later there were completely shot.
The Moog track bar bushing also didn't last more than 3/4 months.
This is all city/hwy driving and I never pulled anything.
In Dodge world the XRF ball joints are very highly regarded and those trucks are well known to be very hard on front ends.
I am currently using XRF product in my vehicle as we speak and will happily continue to use it until something changes to make me think otherwise.
The XRF website might be lame but I wouldn't let marketing affect my judgement on a product if I felt it was otherwise solid. Although there have definitely been times when that was not the case
