Door Jamb Rust
Door Jamb Rust
I was reading on here a while ago that a lot of other guys have the same rust issue as I do but can't find where I was reading it. There is a lot of rust on the front bottom of the door jamb, is there patch panels made for this or am I stuck hacking up a junkyard truck? Both sides are rusted through and the door rubber doesn't even cover it all, any advice is appreciated.
Does this look right
Ford - Ford Pickup Truck Door Patch Panel - Lower Inner - Right Side - Macs Auto Parts
The description sounds right but the pic doesn't, probably just a generic pic.
on
from like Home depot cut to size use Pop rivet to keep it in place and brazed then did the side filed any humps &bumps used bondo it in where needed.
It's bend 19 yrs ago and still no rust bubbles coming through to blister the paint.
I drilled a hole on the back side and sprayed galvanized paint to hold off any rust from forming.
Orich
jvmcc
05-31-2014 04:04 PM
80s Trucker
1997-2006 Expedition & Navigator
01-16-2011 09:36 PM
spudtang92
03-10-2005 03:02 PM
