1990 f250 no spark
1990 f250 no spark
I was doing an lower intake gasket job and when i put it back together it had no spark. When I unplug the spout it does have spark but no run. I did connect the batter and jumped the starter so I could set the timing to remove the distributor.. Could this have fried something? -1990, 302
It does not sound good for the PCM Computer by getting spark with the SPOUT out and not with it in. I take it the injectors are not firing either.
More than likely you may have left a wire off. I am not someone else but if you do not have power to the computer or if it dose not have good ground it may also do what you are talking about.
You do not give any other information, as do the fuel pump run for one second each time you turn on the key? I am guessing it does not.
Does the PCM Power relay close when you turn on the key (brown bottom)?
Does the battery neg post have a wire going to the body (not the frame) and have other small wires hooked to that point?
From the NEG post it should go to the body. Then there should be at least two wires at that point. One of the wires is black with a white stripe and the one that goes to the computer pins 40 & 60 is black with a green stripe.
That wire is the ground for the Computer and other items.
When you turn on the key the EEC Power relay should click (make) and send power from the yellow wire at the base of its brown socket to the red wire that goes to all of the injectors and other places.
Also when you turn on the key the Fuel pump relay should click (make) and send power from the yellow wire at the base of its green socket to the brown wire that goes to the Inertia switch and on to the selected fuel pump by way of the selector switch on the dash for one second and then drop back out.
As you can see in the below diagram #1 there is not much difference between how the ignition system works with the spout in or out. With it in and no spark the SPOUT (called timing test lead in the diagram #1 below) is keeping the ICM from firing the coil.
If replacing the computer does not change anything then you are not getting power to the computer (pins #1, #37 & 57 in diagram #2 below) or it does not have a ground (pins 40 & 60 in diagram #3 below).
Power to the computer comes from the power relay in diagram #2 below. Also make sure that fuse link #N is not left off of the battery side of the starter relay (solenoid) on the passenger fender (in diagram #2 below). Also make sure the fuse link is still a good one by stretching it. If it stretches it is bad.
Diagram #1:
Diagram #2
Diagram #3:
Diagram #1:
Diagram #2
Diagram #3:
