89 f150 surge ??
89 f150 surge ??
so i got my son an 89 f150 4x4 with the 6cyl and it has a surge during warmup and then also when we drive down the road it feels like it misses every now and then. CK engine light is not on, havent done the normal tuneup yet but going to when i get the bronco out of the garage. anyone have some ideas about the surge at idle. Thought it was the IAC so i changed it out with one i had laying around and it does the same thing. Maybe the TPS?
Thanks
Tim
Thanks
Tim
Elkarcher171: Check out the following for my two cents:
https://www.ford-trucks.com/forums/1...l#post14967023
What testing did you perform?
Instead of blindly replacing a part why not measure the signal output first? FYI...many aftermarket TPS are bad right out of the box. I highly suggest you measure the one you have. A quick code check may also keep your wallet thicker.
bobbyk01
01-19-2015 06:40 AM
rcwells
12-08-2007 04:52 PM
Todd Varvel
1997 - 2003 F150
09-26-2003 09:25 AM
