Park Brake lever boot 48 - 52
I'm not trying to eliminate all the air and noise leakage problems in my truck with this boot. Just the one.
I'm thinking I need to close up that one hole when I'm sealing the rest of the floor. Maybe a rubber floor mat will do that adequately.
But my wife just agreed to make a boot for Betsy, so I'll be sure to post pics of that when it's done.
Of course, I could always buy one of these from Amazon and be done with it.
The one I showed first from Summit is too big.
Last edited by Jolly Roger Joe; 01-05-2015 at 12:55 PM. Reason: The one I showed from Summit is too big
Joe, here is a scan of the McMaster-Carr catalog. The one I'm thinking about using is 74405T82, the second one down under black nylon fill 5/16" thick. I'm also looking at the D profile brush holder 74405T98. Their phone # is; (404)346-7000 or www.mcmaster.com
Mark
Mark
They didn't tell me there would be math and geometry.
I picked up a boot from Midwest Early Ford last summer for $5.00, they listed as EB-7000-B for 48-52 Emergency brake. They were the only one to list it. They show a drawing of it in their catalog, but no picture on the website.
After some research, I found that Mac's sells what appears to be the same thing as an emergency brake boot for Ford Model A 1932-36
http://www.macsautoparts.com/ford_me...bber-ford.html
The original "boot" was actually a block of foam rubber, like the pad that goes around the shift tower. It was 3/4" thick, 4 1/2" long, and 2" wide. It had radiused corners, like the hole in the cover. It had a slit around it's circumference, so half of it stayed below the cover, and half above. The hole in the center was 1" x 3/8", also with radiused corners. Real simple to make from material available at McMaster-Carr. M-H used these for their transfer case levers as well. They probably bought them from Ford.
Chuck
Chuck
Mark, I can't remember how I did it. I have the rubber mat, I'll have to get back out in the barn and look to see if I put the square flange on top of the mat or under the mat.
#28
Ford - Ford Emergency Brake Boot - Black Rubber - Ford - Macs Auto Parts
#30
