I'm looking at an 87 f150 with the rear sliding back window. The back right pane is busted out. Would it be very difficult to just go to a junkyard and get that pane or do I need a whole new peice.
You have to remove and disassemble the whole window to replace that one pane.
Yep, the whole thing has to come out to replace that pane. Learned that the hard way myself. You can probably find it, but as you have to take the whole thing out anyway, you might as well look for an entire window to replace. Twine, twine is your friend when it comes to the seal! LOL
I did last summer. Two flat-blade screwdrivers to take it out. It's easier with the sliders open, it allows a bit of flex. Put it in with twine and dish soap.
It takes LESS than 30 second to put the rear window back in with a 15' piece of string and ZERO risk of scratching the paint or breaking the window like a screwdriver will
