None too happy with Ford/ESP right now
#77
#79
#81
#82
GEICO
Ford has history of letting the customer down on warranty repairs. I just don't know if any auto manufacture is better. I feel for you, I had my issues with Ford on my 6.0.
On Geico, they have been a great company for me over the years. I am sure they will get the beast back to you.
On Super duty you do have a point that the truck they advertise does is not the truck they sell. It a bait and switch issues, you could have recourse under this. It would must likely cost more then the repair.
#83
Yeah I had mbi on previous vehickes but I checked it on this one and it would raise my premium 300 the first yr and I think at three yrs it goes up alot and yearly after that,so not worth it to me in my case anyways. I instead got the esp for 1000 7yrs... I think its bs what hes going through with ford on this repair but You cant take one thread and decide esp isnt worth it.Ive seen multiple threads with an entire different story praising the esp from ford.And dont think you cant get hassled by geico.Believe me you can. I had a repair filed with them that took a yr of my time to get covered.So they all have their issues.
#84
I appreciate all the comments, guys.
I can't quite talk myself into defending this dealer or holding them somewhat accountable in all this.....
I just don't know how much they're accountable in this, versus the Ford corporate ESP department I've spent most of my time arguing with now. They are our company's "preferred/local" dealer, we've bought vehicles from them and have all the "non-PM" service work done by them. I can only THINK I'm being treated fairly, but when my service writer says things like "I'm not going to waste my time cleaning out that caliper/rotor, I'm just replacing it", then I know he's not being honest with Geico. Or is he? I mean, I'd clean it out and run it, but is he covering his *** from some potential failure down the road? Who's to say?
I've got access to car haulers and one-tons and a helluva washrack here, and if I'd have known then what I know now, I would've picked the truck up myself, cleaned the everliving **** out of it, and THEN dropped it off, where?......I dunno, maybe I could think of some non-dealer alternative? But I didn't know to suspect their treatment of me and my truck at that point. I knew it needed body and mechanical repair, and I knew I had warranty coverage, so "dealer" popped into my head immediately. I just didn't even consider anything else.
Too late now.....but yeah, won't be getting anymore business from me. And Matt, I hear ya on the "dealer vs. brand" issue, and hell I even levied that same thing to Dim Sum Steve (why not just trade your lemon for another Ford?) but I now completely understand why Brett said what he said "we can't continue to support businesses that don't support us" and expect them to change anything.....
#85
#86
My read of the letter pins this on 'off-road, non-manufacturer installed components'.. aka the lift kit..
not dirt, not speed, not carelessness..
(I don't agree) so the sentence goes, you changed the product setup from the way WE support it for non-paved road (offf-road) use. That change makes it no longer warranted.
as an example I WOULD agree with, lifting, then leaving the stock shocks on, and one breaking when it bottomed out. no covered.
the lift changes the forces on all the components. I don't know how much, but something.
#87
Sam- see my post in response to 96Sherm's comments almost identical to yours:
https://www.ford-trucks.com/forums/1...l#post14967569
This wasn't the "factory/stock" warranty that I violated or went outside the scope of. The truck, just as it sits today, was thoroughly inspected by their authorized rep at the dealer prior to the extended coverage being agreed upon and enacted. He made specific mention of the "oversized tires" in the comments section of the report.
If they wanted to say "we can't cover your truck due to " that's all they had to say, AT THAT TIME.
Don't take my money and then give me the finger when my FOUR WHEEL DRIVE truck has some mud on it when a ball joint decides to fail
#88
I am sure there is some clause hidden somewhere that says "just because our agent didn't see a problem, doesn't mean we are bound by that. The paper wins"
(sorry, lawyers in the family, and we spend lots of time talking about contract contents, intent and factual details. Always eye opening!)
#89
Yeah I understand what you're saying about fine print and all, but, again, this wasn't one of the "lift" components failing, I wouldn't have expected Ford to cover that.
And to be clear, the "lift" is those upper spring perch spacer thingies, and 350 rear blocks. Or, basically, snow plow prep springs on an F350, or basically, no lift outside of what OE Ford also offers.
What failed on my truck was an OE component that is specifically mentioned in black and white on the premiumcare brochure:
Ball Joints
(Upper and Lower)
• Control Arms (Upper
and Lower)
• Control Arm Shafts
and Bushings
• Kingpins and Bushings
• Linkage and Bushings
• Load Leveler
Suspension System
• MacPherson Struts
• Roll Stability Control
• Spindle and Spindle
Support Springs
• Stabilizer Bar
• Tie Rods
And I mean, I'm not trying to pick a fight with you, I just want anyone that comes along to be clearly informed. There is NOTHING about my situation that lets Ford out of their responsibility, period.
Ball Joints
(Upper and Lower)
and Lower)
and Bushings
• Load Leveler
Suspension System
• MacPherson Struts
Support Springs
• Stabilizer Bar
• Tie Rods
