Need advice on painting?
These videos show how to remove the cloudy anodized finish so you polish it.
https://www.youtube.com/results?sear...+aluminum+trim
These videos show how to polish your trim.
I've polished a few pieces of my trim, and really like how it comes out, it's beautiful. But bare polished aluminum is vulnerable. It will discolor and even corrode if it comes in contact with certain cleaning products and solutions that you would have never thought would be harmful to it. Salt is another problem for it.
Once you polish your trim, you have to continue to polish it to maintain the high shine, but it's not very often if you are careful with it. Applying wax on it just as you would on your paint is a good way to get some temporary protection.
David
David
Last edited by rougeriver; 01-05-2015 at 03:22 PM. Reason: oops! I posted a youtube link to a playlist. Temporarily broke the thread.
Good-to-doo,
If you are going to use Plasti-dip then all you really need to do in my opinion is to just give it a good wash. My son did the wheels on his Mustang with Plasti-dip. Applied about 3 or 4 coats and it's held up just fine. I personally don't care for the look because it will leave a rough texture and after a while it will always look dirty. However the good news is that you can quickly change the look of your grill with it and if you get tired if it, it can peel right off without causing any damage. I would avoid doing any sanding or removing the factory anodizing unless you are going to actually paint it with paint. That is what is kind of cool about Plastidip. Minimal prep is needed and it's fairly cheap to experiment and touch up is only a shake away.
Keep in mind that the front of the truck will always get hit with bugs, rocks and other things that will chip hard paint and the Plastidip might be a little more forgiving than hard paint.
Austin Burden
13
04-15-2019 08:21 AM
49willard
01-17-2007 08:27 AM
