2002 5.4L F150 Bad Fuel Pump?
Old 01-02-2015, 11:17 AM
jojo40's Avatar
jojo40
jojo40 is offline
Hi everyone, Ive been coming to this site for years and reading these forums and finally decided to make a profile and post a problem that I am stumped on.
Last week my 2002 5.4L f150 4x4 (125,000 miles) wouldnt start until the 4th or 5th try then it ran fine with no change in driving or in mpg. then a few days later it happened again, then another few days and it just didnt start at all. Battery and alternator are fine but I noticed the fuel pump wasnt turning on. So I checked the fuses and relays, all good. Next I dropped the tank and swapped out the fuel pump (used an Airtex) and I also replaced the fuel filter. Truck started but it sounds like it is starving for fuel and it is idling very rough and it dies after about 5-10 seconds (with a few misfires and backfires). I thought it was a bad pump so I dropped the tank AGAIN and put in a new pump (still an Airtex). Started it up and I still have the same problem. I checked the pressure at the rail and it is getting good pressure.
I am not sure what to go after next! Any help would be greatly appreciated
Old 01-02-2015, 12:04 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
What pressure did you measure using a gage?
Good luck.
Old 01-02-2015, 12:15 PM
jojo40's Avatar
jojo40
jojo40 is offline
Good luck.
Getting just above 40psi Which I believe is in spec
Old 01-02-2015, 01:00 PM
Bluegrass 7
Any chance you got a load of water in the gas?
Try one bottle of dry gas and give it awhile to work.
Next, are there any codes set?
Good luck.
Old 01-03-2015, 03:24 PM
sail2244's Avatar
sail2244
sail2244 is offline
fuel pump
I assume you have change the fuel filter, check the fuel pump connector, mine got water in it and burnt the pins
Old 01-20-2015, 09:15 AM
jojo40's Avatar
jojo40
jojo40 is offline
Welp, Turns out I cracked my Intake manifold when I was testing to see if it was for sure a bad fuel pump. My bad got it all fixed up tho. thanks everyone
JoeFord94
06-24-2019 01:23 PM
30093f150
09-20-2017 08:01 AM
brian1080
09-23-2011 07:05 PM
RRAM513
1997 - 2003 F150
01-05-2011 04:01 PM
1yamman350
16
12-29-2003 05:17 PM
Quick Reply: 2002 5.4L F150 Bad Fuel Pump?
