penlum inserts
Received 3,102 Likes
on
The Plenum inserts are on Riffraff's site:
http://www.riffraffdiesel.com/rdp-pl...rcing-inserts/
He has a handy search function, I can't find glow plugs without using it.
Bob
Bob
RDP Plenum Reinforcing Inserts? - Riffraff Diesel Performance
Thank you though.
I really wanted to see if this was a common mod done to the OBS. Every application ive read is just SD,s worried about over torqing there t bolt clamps and causing boost leaks.
We don't make them for the OBS since you are already necked down, to reduce it further just lowers the flow. The Super Duty is large enough that they don't change the flow at all, but when we tested them on the OBS it was too significant of a difference to produce them.
Did you find the OBS to have the same issue?
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Only if a t-bolt clamp is used. If you stick with the factory worm drive I haven't seen any issues since the OBS being smaller it lends itself to being more stout.
Hummer1823
11-16-2005 07:32 PM
