"Belle" 1952 F-1 build thread.
Old 02-22-2015, 12:01 PM
Harrier's Avatar
Harrier
Harrier is offline
Wow! Belle is looking beautiful.
Any chances your wife will let you drive it any?
I can't wait for the start up video. Be sure to post it even if things don't go just right. (Like there is any chance of that happening.)
Truck **** at its finest.
  #92
Old 02-22-2015, 01:52 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Originally Posted by Rimrock F1
First start is going to be very soon and for good or bad we will be filming. I expect no problems but will have a fire extinguished close at hand.
I really want to watch that video, without the need for the fire extinguisher of course!
  #93
Old 02-27-2015, 07:43 AM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
With the exhaust done it's time to get a few things done before the cab goes back on.
I ran the battery cables, which I put in tubing later and installed the original parking brake cable.
Installed the hoses for the remote brake/clutch reservoir.
Hoses will eventually be secured to the top side of the transmission.
The exhaust runs pretty close to the battery and the brake booster......
So I installed DEI heat shields on the sections of pipe near them.
Once secured the hoses will be 3" or so away from the exhaust.
The last thing I needed to install was the oxygen sensors.
Sorry no photos of setting the cab on but it was just Lois and I so no one to take them. All new rubber bushings made the rear mounts a little tough.
Checking the stance. I am very happy! The coil overs need to be adjusted which will raise it 1/2" and the new tires/wheels will raise it a little more.
This is the first time I was able to check the actual engine to firewall clearance, it was right on with our mock-up firewall.
No cutting require anywhere on the cab and the shifter should work fine.
I'm very happy with the way the Coyote fits.
We don't get this often but this was the day after cab install. Fortunately all work will be inside for awhile.
  #94
Old 02-27-2015, 08:26 AM
walt460's Avatar
walt460
walt460 is offline
Would like to see how you secured that engine hoist to your cab floor. I need to take my cab off soon and that looks like a great way to lift it. What do those straps connect to on the cab floor? Thanks.
  #95
Old 02-27-2015, 11:36 AM
pineconeford's Avatar
pineconeford
pineconeford is offline
Knuckle Bandage Sales Rep
So far so good. That cab is as clean as your shop.
I'm surprised you have snow shovel in your tool shed. Odd to see a few inches of snow next to cactus. Hope that stuff goes away soon for you.
Tom
  #96
Old 02-27-2015, 03:24 PM
BlueOvalRage's Avatar
BlueOvalRage
BlueOvalRage is offline
I'm planning an under floor hydraulic clutch and brake master cylinder arrangement for my rig with remote reservoirs under the hood. Imagine my surprise when I read your update and saw pictures in living color of the vision that's been rolling around in my head! I'm anxious to see how it works out. Love your build! It's one of the cleanest I've seen and your workmanship and methods mirror my own very much. If and when I get my bucket screwed together, I'd love to catch up with you sometime in the flesh. Keep up the great work!
  #97
Old 02-27-2015, 07:35 PM
Rimrock F1's Avatar
Rimrock F1
I hooked them to the bottom of the door posts in the front and to my seat belt mounts in the rear. There are some additional photos earlier in the post. Straps allowed me to adjust the balance.
  #98
Old 02-27-2015, 07:50 PM
walt460's Avatar
walt460
walt460 is offline
Mike,
Thanks for posting the pics of cab lifting points! My cab does not yet have seat belt anchor points but I might better so some!
Thanks again,
Walt
  #99
Old 02-27-2015, 08:25 PM
Jolly Roger Joe
Mike,
Thanks again,
Walt
Just use the rear bench seat mount holes for the back.
  #100
Old 02-27-2015, 09:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
I may have missed it earlier in the thread, but I would have thought you'd want the middle shifter location? Maybe even the front location?
  #101
Old 02-27-2015, 09:41 PM
Rimrock F1's Avatar
Rimrock F1
Tom
Snow is long gone. The shop becomes a disaster each day as I work but I clean it at the end of the day of before I start work again....usually just before I take the pictures.
  #102
Old 02-27-2015, 09:47 PM
Rimrock F1's Avatar
Rimrock F1
Thanks for the compliments. It sometimes takes a few tries to get things the way I want. So you don't have to wait for the reservoir install, here is a photo.
  #103
Old 02-27-2015, 09:54 PM
Rimrock F1's Avatar
Rimrock F1
Front location would have put the shifter through the original hole but.... Tremec does not make this kit any longer, if ever. I found one company that does and the trans has to come completely apart and it runs $1200.00, ouch! I considered the middle location but it only buys 3" and runs $350.00 and last and most important!! This is my wife's truck and being a woman she has crap that she takes everywhere. there is enough room in front of the shifter to make a portable storage box for said crap. We had one in another truck and she loved it.
  #104
Old 02-27-2015, 11:34 PM
walt460's Avatar
walt460
walt460 is offline
Fuel pressure regulator routing has me concerned. Please confirm that fuel supply from the pump goes onto the fuel rails and that the return from the fuel rail goes to the regulator which then controls how much goes back to the tank. Right?
  #105
Old 02-28-2015, 07:06 AM
Rimrock F1's Avatar
Rimrock F1
Ha Ha I figured someone to comment that the lies were backward. I had planned on connecting them the correct way which would not have been as clean an install, then I read the directions where Holley tells you it does not matter which line is the inlet and outlet. This way the lines enter on the passenger side exit on the drivers and the pressure gauge is to the front. Good catch, for which you have one a gift! This young lady should be delivering it in a few days.
Quick Reply: "Belle" 1952 F-1 build thread.
