What to do for rear suspension?
What did you do for the front? I'm not trying to steel the thread. Don't know how you can change one without changing the other.
Did it with the bed still on. It does ride a little smoother - even though I still need swap out the stock length shocks. Only other cost was buying hardware to secure the spring mounts. The bottom hole in the frame was the original:
Here you can see how much travel I still have. If you flip the axle you's want to notch the frame probably:
Oxfordrider
11-12-2012 06:07 PM
daves54
02-03-2009 05:19 PM
nate5812
11-04-2004 11:20 AM
