Gary's 1952 F1 Build Thread
#46
#49
Hi guys,
Here is more progress - pics of my gas tank install. Everything is just tacked in and will finish weld everything tomorrow. I used the same tank setup as drpTop70ss. I really liked his setup since it was a good price, I am running EFI, and I wanted the filler to come out the driver side. The only differences from his setup is I chose to mount mine slightly different. I ended up making brackets for the straps out of 1/8 plate and a 5/16 rod (see pics). This allows the straps to swing into place with the adjustment on the axle side.
I never notched a frame before but it came out pretty good I think. I was able to bend the notch plate over some pipe for a tight fit. I also made a boxing plate to reinforce that area.
I mocked up my bed assembly and have about 1/2 inch clearance from the bed wood to the large vent tube on the sending unit. I am debating on installing some type of brace across the tank to protect it from the bed wood sagging and possibly hitting the tank. I don't think it would hurt but it may not be needed....
#51
Received 4,113 Likes
on
#53
#54
It is from a 95 chevy van :-). I used the same tank as drptop70ss. The tank, sending unit, and straps was less than 200 shipped from RockAuto. It fits real good. From what I seen for under bed tanks, most required to fill through the bed. I didn't like that so when I seen this tank I knew it was going to be an ideal option for me. I might add a filler on the fender or maybe out the back some how.
#55
on
#56
Thanks! In the past I haven't posted to my thread as much as I'd like to. I figured it would be a dup post since Ax shared our work as you mentioned. Now that Ax is no longer working with me I will be posting more to share for others and to document my build. I'm excited, motivated, and determined to fire my engine this year!
#58
on
#59
With it mounted under the frame there is about 1/4 -1/2 on each side. The welded seam is under the rails on both sides.
#60
on
