Well this happened today......
So I got this 65 Custom Cab to do a cheaper resto on and teach myself a thing or two. Anyways I decided to take her out for a little test drive today after changing the plugs and wires. The hood was for sure latched but I hit a bump in the road and the sucker flew up. Now I need a new hood, hinges and latch. Problem is in my area there hard to find in good shape. Does anyone make "new" hood? I checked LMC and Dennis Carpenter but had no luck on the hood itself. Also will any 61-66 hood work? It also put a ding in the cowl area where the drivers side hinge bolts in at so now I gotta figure out what I'm going to do to pull that sucker out also.
I am so sorry for you.
'61 - '64 trucks have the "F-100" or "F-250" emblem on the side of the hood.
'65 and '66 trucks have the emblem on the fender, so you will want to fill in the holes.
They should all interchange, though.
Considering the scarcity of hoods, it might be worth it to be looked at by a good body shop.
Best of luck.
John - Banjo
Best of luck.
John - Banjo
I just found a hood a couple of months ago. I travel to different states so I am constantly on Craigslist. It took six months of searching near by various states. I hope u get lucky. Chevys are all over the place. One thing about hoods they are the hardest to get straight. Require a bunch of work.
This is a common problem. My trucks previous owner had this happen. Not sure about 65 hood latch/emergency latch, but 64 you can drill hole in emergency latch and pin or pad lock it.
Here is another post:
http://www.slick60s.com/viewtopic.php?f=5&t=912&hilit=drill+a+hole+in+emer gency+latch
Appreciate the link, that helps. Thanks.
Fellow owners it is very worth you time to spend 20-30 mins lubing and aligning your trucks hood hinges and hoodlatching system.
Use whatever brand that you think is best. Start with the hinges, lube and work em, lube and work until they move smoothly 30-50 time not too many.
Slowly lower the hood to the latch and look at where everythings sits and or needs to sit. Don't be afraid to straighten dented places, slap the safty back to where it's straight. Again lube & work until you can place it down and lightly push it and hear it click, click. Release the latch and know the safetly is in place and working. This is the method that I use and describs how my hood locks.
Holes & pins are for theft, and if you feel that you need it, please install for that purpose. It is not needed for solid hood laching.
John
John
Chains make to much noise. Unless your worried about security from theft, pick yourself up a driver or pass side seat belt set at the salvage yard and use it as a safety for the hood. You already have the metal ends to bolt it down. Should be able to reach inside the grille to release it.
However, I do agree with John, if all those parts are functioning correctly, your hood should latch easy and the hood safety should keep that hood from flying up. Course unless your pushing over 100 down the road. ;o)
Ouch!!! Agree, what a bummer!! Problem is trying to locate a 61-66 hood can be as difficult as finding hen's teeth. I am fortunate to find an auto body person who can work miracles, suggest getting a couple body shop opinions, and quotes if the hood is repairable. Many years ago I located a hood thru Ebay; I set up daily email notices under 61-66 Ford parts and narrowed the search field to distance I was willing to travel to pick the item up. Notice a seller happened to be in close proximity listing numerous 65 Ford part so email and found he had the hood put did not list because did not want to deal with shipping. May get lucky???
Another sad member of the Flying Hood division. I can truly empathize with you, I have the much coveted Night Qualification badge myself. You must have been moving out pretty good, judging from the damage?
One thing for certain even if the latch is serviced, aligned and lubed and/or replaced, everything working perfectly, it's impossible to ever quite fully trust it again. Particularly when those huge wind gusts blast at the truck from oncoming big rig semis on two lane highways.
I'm thinking of a quick disconnect between short length of vinyl coated 3/8 steel cable, something like that, at least for longer trips and peace of mind.
