Axle/Axle swap questions.
What these guys are saying is that a ZF6 from a 7.3 Super Duty truck will bolt right up to your engine. The issue is that the ZF6 you have is from a 6.0 truck (2005), and not a 7.3 truck (1999-2003). If you get the right ZF6 transmission (from a 2000-2003, because I don't think you could get a ZF6 in '99 truck) it will bolt right up to your engine, then you just have to deal with the structural issues to make it physically fit in the truck.
I think it really is what I want to do. That said, I will look into finding one from a '99-'03 7.3. I know a guy that sells rebuilds, I'll give him a call, and see what pops up. The swap wouldn't be occurring until the summer at the earliest, which would give me time to get, and rebuild the D60, so I can do both at the same time.
Thanks for the advice on that, guys.
I have two other questions. One of which is probably kind of silly.
After I redid my UVCH I had a severe diesel leak. There's a little lever that's under the "decorative" hood that covers the ICP, Glow Plug relay, etc. Is it some sort of a bleeder valve that I could have nudged when I was pulling the cover off? Not quite sure what to think of this. Pushed the lever back, and I think the leak has stopped. Any guesses?
Next question-
During the tear-down to get the new gaskets in, I pulled what I assume is some sort of breather, it was black, plastic, and on top of the Valve Cover on the drivers side. It had a bunch of white, kinda milky gunk in it. I believe that is an indicator of a coolant leak, and/or a whole lot of blow-by? Can anyone confirm/deny that for me?
Next question-
The little yellow lever you're describing is the drain valve for the fuel filter housing. Sounds like it is working!!
The breather you're talking about is the CCV (Crank Case Vent). A little milky oil in the CCV isn't an indicator of much unless you're also losing coolant. Some condensation can occur there just because of differences in temperature and other reasons. Keep an eye on the coolant level in the degas bottle. If you're not losing coolant, I wouldn't get too upset.
limalimamikefoxtrot
09-19-2010 12:33 AM
