Need help with locating heater hoses.
You can eliminate the hose going across the top of radiator too. I did. On the 95 and 96 some had a short nipple welded to the metal heater hose coming from the water pump, at the top of it next to where the 5/8" heater hose goes to the core, right above alternator. It is a much simpler solution, and much cleaner looking. Worked great on mine.
The Ford Engineers must have put it there for a reason. They would not spend all the money to produce these parts and pay for people on the lines to manufacture it and then install it on the assembly line.
Beginning in the 1980's, FoMoCo introduced heater hoses that have metal ends swagged onto them. What auto parts store has any? Back then...none, today I dunno.
80%+ of automakers profit comes from the sales of parts, if parts don't fail, no profit for automakers.
If the parts are available at auto parts stores, no profit for automakers.
And btw: In addition to stocking bulk heater hose, dealers now had to stock dozens of these new hoses...which were installed on all FoMoCo vehicles, not just trucks. T'was a PITA!
I recall a customer had an Aerostar, needed one a these hoses. It was on national back order (D99), no one had any including FoMoCo...estimated time of arrival, 2 months.
So we used a 5/8" nipple, spliced it into the hose...away he went, happy as a clam.
For many years, trucks used bulk 5/8" heater hose that used clamps to retain it.
Beginning in the 1980's, FoMoCo introduced heater hoses that have metal ends swagged onto them. What auto parts store has them? Back then...none, today I dunno.
80%+ of automakers profit comes from the sales of parts, if they don't fail, no profit for automakers.
If the parts are available in auto parts stores, no profit for automakers.
And btw: In addition to stocking bulk heater hose, dealers now had to stock dozens of these new hoses....which were installed on all FoMoCo vehicles, not just trucks.
But if the swagged ends are bad (usually they aren't...but sometimes they become disconnected from the rubber portion), you're stuck. Have to replace the entire hose.
If the rubber portion is bad, you can splice in a metal or plastic nipple with the apropos 5/8" or 3/4" hose.
I then found both of these hoses NOS, so it's up to you whether you want to buy them or not.
If there's enough of the rubber hose remaining that is swagged to the metal ends, you can just splice in new hose using a nipple and the apropos amount of bulk heater hose.
The way I look at this problemo is: Post 13 = I found the Ford part number (E9TZ-18472-A) for the one hose you were unable to, verified that the other hose (F2TZ-8555-C) was correct.
So I replaced my water pump and hoses a few weeks ago except for 2 of the heater hoses which I can not find anywhere. 1990 F250 460 E4OD
The metal one I found the part number is F2TZ-8555-C I found a place online that had that but then I got an email this morning saying they cancelled my order because it's no longer available. The other hose goes to the heater core but joins with the metal hose and I have not been able to find that or the part number.
I know what you mean as far as being "RIGHT". Look at the pic though. That hose goes from a heater hose back to the radiator neck. It serves no purpose on this truck, unlike the ones on the 5.0 and 5.8. That's why I changed it to this routing. Eliminated that long nuisance and took advantage of the newer design. Yours though does absolutely nothing.
#29
I understand. Every time I see stuff like that on these trucks it makes me wonder what the Hell these engineers were thinking. I then remember something my grandfather always said, "Take an idiot and educate him and all you have is an educated idiot." Always makes me smile and be thankful for sites like this where lots of wisdom can come together in one place.
#30
I hope I can cap off that hose location on the radiator with no problems, lots of heat and pressure.
