Diesel Oil Lab tests
Old 01-05-2015, 10:11 AM
Gettysburg150's Avatar
Gettysburg150
Gettysburg150 is offline
Originally Posted by Chevy_Eater
Real world on the street testing, performed mostly by a large percentage of women, have shown conclusively that:
OIL > NO OIL
End of test results.
Skirts always know best
Best results are always to have oil in the engine, and clean oil on occassion probably helps longevity (shh, don't tell the secret )
Originally Posted by idiabuse
Not one single diesel engine was tested in this "TEST" not on single used engine oil analysis was done.
Yawn boring almost useless data here...
For a test of oil quality I'd rather see information NOT biased to one engine and just the properties and qualities of the lubricants in question.
You didn't have to read the whole thing if it bored you
Old 01-11-2015, 06:34 PM
idiabuse's Avatar
idiabuse
idiabuse is offline
I did not read it all I knew what the intent was all about testing un used lubricants instead of actual real world testing.
wear rates after the lubricant is being used is the only results I value, not this pie in the sky debate
Old 01-11-2015, 08:50 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
This is exactly why I no longer care about oil......It is almost IMPOSSIBLE to prove that poor oil was the cause of engine failure, your bearings crap out it's possible you had a bad batch, you got the engine hot, you got a bad filter, you never changed the filter...... everyone worries so much about their oil yet engine failures due to the "wrong" oil is rarely ever heard of, and almost never proved.
Best advice for a diesel owner............ put oil in it and run it HARD.....babying a diesel is just asking for problems.
Diesel Rod
Old 01-12-2015, 01:38 PM
Gettysburg150
Diesel Rod
After you reach operating temp, of course
Old 01-12-2015, 03:15 PM
444dieselrod
not really, none of my diesels ever idle more then 5 minutes. Idling just wet stacks everything...Get in an drive it, fastest way to warm them up.
Diesel Rod
Old 01-12-2015, 03:23 PM
Gettysburg150
Diesel Rod
Gotcha
I always let mine get the oil pumping for a couple minutes before ever moving, specifically in the winter.
I don't hard load them till theres a little heat in the engine, I've always been more concerned about having oil in the bearings more so than wet stacking. I always make sure to "blow em out" good though once things get moving
Old 01-12-2015, 03:34 PM
madpogue's Avatar
madpogue
madpogue is offline
How long you idle it is completely irrelevant to how long you wait to run it hard.
Old 01-12-2015, 03:39 PM
Gettysburg150
I would have to argue that if you run the engine at fuel cut off immediately after start up on a sub freezing day that the engine longevity may be diminished
Old 01-12-2015, 04:02 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,103 Likes on 2,165 Posts
i fire it up cold and drive very slowly to the deli 3 blocks away on the highway.
then i let it warm up while i get my coffee, paper, and lunch.
that takes 3-5 minutes.
by then it is warm enough to drive out on the highway.
Old 01-13-2015, 08:21 AM
Gettysburg150
If its cold like it has been recently (20 deg F and below) I usually wait til the fast idle shuts off, then drive slow for the 2 miles it takes to get to the main drag, then its normal crusing speeds (55-60)
IDK if it's overkill or not (probably) but I'm usually not in a hurry when I'm driving one of the two, guess thats why my IDI's are a good fit
Old 01-13-2015, 01:46 PM
444dieselrod
I should have stated that better....NO I do not get on the hwy and floor it cold. Here in the frozen north it has been -15 every morning for the last week, I try not to rev it much past 1500-1700 till it's warmed up a bit.
Diesel Rod
Old 01-14-2015, 09:16 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
Blond adding oil:
Just like doing a load of laundry, right?
  #28
Old 01-15-2015, 09:18 AM
Gettysburg150
^Thats fair, you ever see how rusty those junk mini's get?
4tl8ford
16
08-25-2008 07:33 AM
monoman
Oil & Lubrication
02-21-2006 04:30 PM
tinytrixie
10-23-2004 01:16 AM
gtm245
Oil & Lubrication
34
06-05-2004 05:42 AM
Twin Tritons
05-25-2004 09:14 PM
Quick Reply: Diesel Oil Lab tests
