Radius Rods
Have you considered any of the other wandering fixes that folks here have used? I too started off looking for a set of the land Yacht Radius Rods but since they are no longer produced.................. I went with a full spring swap from a SuperDuty, other have gone with the RAS. There are also aftermarket traction bars that function just like the radius rods, these are some very high quality units One Up Offroad
There are fixes out there for you, it all boils down to how you use your EX, what your desired ride and performance are, stock ride height or some lift and of course your budget.
Tom I put on RAS. It doesn't jump around when I hit a bump much at all and when I put the Hellwig ASB on I believe that part will be fine. This truck wanders going straight on a flat, relatively unmarred stretch of highway--curves are almost scary--and I owned a 2WD Excursion for 10 years so I'm used to the feel of the truck by size and weight...******* has a mind of its own.
If after RAS and a Hellwig it still wanders then I would say it's time to seriously go through the front end components like Magnus said. It seems that the factory installed wander (on rigs that suffer from it) mostly comes from the rear springs, the RAS and Hellwig should tame that, additional wander beyond that sounds like just age/miles catching up with the front suspension parts. My EX didn't suffer from any wander at all running solo with everything stock at 70k miles, with the heavy trailer behind it the combo was almost uncontrollable! New beefier springs front and rear corrected that.
Wandering is often a symptom of incorrect alignment. Too little caster and ANYTHING will wander all over the road. Start with the simple fix first and get that checked out by a competent shop.
My Ex never wandered on the stock springs, I don't think that's the issue. Stewart will disagree with me.
Looks like I have quite a selection of factors to eliminate or address. I live 150 miles out in the wilderness in MT so many things I do myself. I'm heading back home so this 150 mile leg I'm going to tighten steering box a bit more and check air pressures. I plan to check all the tie rod ends and drag link. I've already replaced the steering stabilizer--not much, if any, help. Roadmaster Suspension is on and Rear anti sway bar is going on. Got new bushings for front anti sway bar. I've had it about a month and it is challenging with projects which for me, is good being out here. This steering deal just seems to be one of those "I'll replace this part--well that didn't work-next on the list" Just to have to get psyched up.
As for your Ex, yours had an exorcism done on it because 4x4 OEM Excursion springs are eeeeeeevil!
Stewart
FWIW, I drove Orlando to Tampa (FL) and back today with 20-30 mph crosswinds and had no issues with wander: the ras, rear hellwig, redhead, proper alignment, good front end and good tires at proper inflation all play a roll.
My former '97 tahoe drove like a boat, constantly sawing the wheel to catch it wandering, banking on the interstate was a nightmare. My ex, when I bought it 4 years ago wasn't as bad, but it wandered. The redhead, which I did last, made the biggest difference.
on
My X wandered badly from day one of me owning it, purchased at 17k miles. It was so bad I was going to trade it in after a month! After reading and searching the internet I found this site and did the easy stuff. Tightened the gear box which made the steering a bit more twitchy! I installed air bags on the rear springs only because I had them from my previous van, not much help. Then I went with the Hellwig rear sway bar, this was by far THE mod that cured my wander. The reason for the wander is the poor excuse for springs they put under the X. They allow the rear axle to steer the truck with the slightest movement! That is why the Superduty truck springs fix the wander. the Hellwig helps to somewhat control the rear axle movement, virtually eliminating the wander. The stock X springs were designed with ride quality in mind and not hauling/towing.
As I said I just got this car a few weeks ago. Driving from Billings MT North in wind and snow, there was improvement from the steering box. Proper bolts finally came today for the Hellwig. One fun thing I found, I got out and checked the air pressure--it was at 65 lbs/tire--that is ALL 4. Setting those properly helped...so Hellwig this weekend and then go through front end
