Running light/Turn signal fuse?
#31
That makes sense Joe. Now I did notice you had the ammeter listed with a 30 amp fuse. How will it have a fuse since it is one of the wires that will power the box after it runs through the gauge? I currently have a fusable link in the wire from the alt to the 30 amp circuit breaker, and I was going to put one on the wire from the solenoid through the ammeter and eventually ending at my fuse box, but if it's powering my box how will I fuse it with the fuse box? Did you install one of these between the solenoid and fuse box?
#32
#34
#35
Well, actually, I don't remember how the ignition switch is marked, but I think it's A for ammeter, G for gauges and I for coil. I crawled under the dash to look at it, but I can't read the back of the ignition switch. Bad eyes and bad back. Sorry.
#38
Same hear Arctic Y! I don't have an original ignition so I couldn't say how they were done in 49. If they wanted to go that route then why is there an I for coil, shouldn't it be a C?
#39
Why on earth would there be a ground contact on the ignition switch? I believe it is actually marked "GA" for gauges. "Ignition" is more than the coil, it's anything you need or want to be energized only when you are running. The way the switch is circuited internally, everything on the GA and I terminals are all energized when the switch is in the Run position, but in the Acc postition only the accessories are powered up. It's exactly like a modern car, Accessories like the heater fan, wipers, radio, etc. are connected to the GA terminal. That way if you are sitting listening to the radio but not running the engine, you don't fry your coil.
#40
#42
And I think the most common abbreviation for Ground is GND. "G" is usually Green.
Oh, and speaking of "Why on earth would there be a ground contact..." when I got the truck, the PO had run one of the wiper motor switch leads to ground...
#43
That would be great, but I live close to Fairbanks. I'm guessing you don't get up here very often. I'd like to see your part of the state sometime though, but it's unlikely since I will be moving in June.
#44
Oh, and speaking of "Why on earth would there be a ground contact..." when I got the truck, the PO had run one of the wiper motor switch leads to ground...[/QUOTE]
Funny because if I remember right the PO of my truck had a ground on the ignition. Ross straightened that out pretty quick though.
I can't wait to get my truck back so I can get to work!
