Best axle combos for 40s
Received 3,102 Likes
on
on
there is no "easy" D-60 swap.
the D-60 is a leaf spring axle, the F-150 is a coil spring truck.
to put a D-60 in a F-150 you will either have to convert the axle to coil spring perches, convert the truck to leaf springs, or fabricate things to use a 2005 and newer F-250/F-350 coil spring D-60
I think it'd be perfectly fine runnin 40's to patrol pavement. These trucks are light and power is very low...that helps a lot. Of course, my opinion based off my experience.
I ran the d44 with 37 military oz for years, and I put it through some gnarly stuff cuz i didn't care about breakin anything, as it was and still is primarily a 4 wheelin rig. It never broke, but when it needed a rebuild (I.e. u joints, bearings, seals) I swapped in a d60 cuz I have a bunch that I've collected from the jy over the years.
I had some 38" TSLs on a 78 F150 and broke shafts EVERYTIME I went out, but those were much heavier and had much more traction on the trail. I'd have to replace ball joints twice a year sometimes.
You must have lighter foot then me, as I also ran those same 37" military surplus tires on an old 76 3/4 ton. Axle stubs were broke atleast once every wheeling season, even with an open diff and a stock 360.
I had to rebuild back to the ball joints plenty. I don't even know how often, but I musta done it half a dozen times over a 5ish year period. bearings destroyed, etc....the fact that it was a 302 helped plenty. light foot, heavy foot, didn't matter...it wasn't powerful enough to make a difference.
I ran it unabashed with that setup, like I said I didn't care if it broke cuz a d60 would go right in at that point...I was amazed it held up. rear was locked, open in front....I wasn't breakin any records but violent hill climbs and being stuck in mud, with 1000 first to reverse jams, was commonplace.
maybe I was lucky, maybe I wasn't.
on
cab chassis dual rear wheel trucks kept the pre 77 narrow frame.
I'm not saying that a Dana 44 can't live with 40s. If you're careful enough anything is possible. What I am saying is that I'd never go to the effort of swapping in a solid Dana 44 if I was planning on 40s. I'd MAYBE try to see if the stock TTB 44 would hold up, but if I was going to swap in a solid axle it'd be a Dana 60.
Just sayin it's a waste of time if all its gonna do is see roads. Plenty of toothpicks out there with big tires on the ends that last lifetimes without breakage.
