1978 f350 460bigblock high idle problems
There are other causes also depending on what has been done, modified or repaired on the vehicle.
Since you say "in order to drop the idle back down" I am taking it that it will idle normally at times and stick as you slow down from driving it. It may be as simple as a dirty choke/linkage sticking. Spray the choke and linkage with carb cleaner. It could also be a worn or damaged throttle linkage that is sticking. If you have an automatic transmission, the transmission linkage could be binding. Or if anyone has removed/messed with the air cleaner assembly it may have been put on incorrectly and is binding the throttle linkage.
...or a weak return spring.
Lowpala
11-15-2015 07:52 AM
yellow78ford
03-23-2007 12:29 AM
