turn signal cam
turn signal cam
The turn signal cam is different on a Tilt column as opposed to a non-tilt column.
The cruise control has no effect on the T/S or wiring harness except.
When you go from Non cruise to cruise control, the previous wiring from the Horn changes to the power for the cruise.
This is done with a special harness for the horn which is added to the system.
So no, the cruise control pad is just that a pad fitting into the same spot the non-cruise horn pad fit.
Bigbruce
06-23-2013 08:35 AM
mrwildcat2u
03-04-2012 01:37 AM
ozark1
02-16-2007 08:26 PM
