2000 F150 Clutch Problems - Ford Truck Enthusiasts Forums
Old 07-20-2003, 08:27 AM
hhouse hhouse is offline
hhouse is starting off with a positive reputation.
I bought a 2000 F150 XL V6 5 speed last fall and shifting into first and sometimes second has always felt a little tight. The clutch pedal has 3-4 inches of play and when I took it to a mechanic 6 months ago, he said it was fine and didn't need anything. I also think he was in a hurry and couldn't work me in to look thoroughly. This shifting problem comes and goes, but has recently become very difficult. Today, I have driven it 3 times in 3 hours and the 1st time it was fine, the second almost impossible to get into gear, and the 3rd time was fine again. Any idea what is going on? There is plenty of clutch fluid. I looked for a bleeder valve but don't see one, so if I can bleed this, I don't know how to go about it. This truck has 51K miles and I believe has never had any repairs done.
Thanks in advance!
Old 07-20-2003, 08:32 AM
GR8Diesel GR8Diesel is offline
GR8Diesel is starting off with a positive reputation.
Usually a clutch that is failing to fully release will make it's presence known by grinding when attempting to engage into a non-syncro gear (usually reverse). I does sound to me that you have too much play, but I haven't driven it.
If the clutch is dragging, you will wear out the synchros in the tranny very quickly - this I know from experience.
Not much help I know, keep us advised of your findings.
Old 07-20-2003, 08:54 AM
Doesn't really grind and getting into reverse isn't bad. It's mostly getting into 1st and 2nd.
Thanks for the input.
Old 07-20-2003, 08:56 AM
I'd check for adaquate lube level in the transmission.
Just a thought...
Old 07-20-2003, 12:10 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi hhouse and welcome to FTE
3-4" of pedal free play is too much.
The bleeder screw for the clutch is on the side of the bellhousing, just above where the clutch fluid line goes in. Usually you can gravity bleed it. Just open the bleeder and let it run while keeping an eye on the master cylinder to make sure there is lots of fluid in it.
Make sure when you fill the master cylinder that you remove the rubber cup/gasket from inside. Lots of people fill that up and wonder why their clutch doesnt work.
Old 07-20-2003, 12:55 PM
Thanks Racerguy; I looked all over the bellhousing, but I'll double-check that.
M5OD Noise as Clutch engages. yeahoner Clutch, Transmission, Differential, Axle & Transfer Case 4 06-24-2015 01:01 PM
4.9 with M5OD Noise as clutch engages yeahoner Ford Inline Six, 200, 250, 4.9L / 300 1 06-16-2015 08:13 PM
Difficult to put in gear? 03 F-150 R1_Demon Clutch, Transmission, Differential, Axle & Transfer Case 21 11-12-2012 09:22 AM
New clutch, shifting still has "stiffness"??? jerrylynnb Ranger & B-Series 25 03-10-2012 04:50 AM
2000 4R70W no 3rd or OD bigbuick 1997 - 2003 F150 1 11-21-2010 09:19 PM
Tags
150, 1997, 200, 2000, 2003, bleed, chattering, check, clutch, f150, fluid, ford, inspection, play, problems, screw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
