Poor Tolerences on New Wheel Bearings?
Old 12-30-2014, 04:49 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
I had the same thing happen to me 4-5 yrs ago with my truck. Bearing was too small. It wasn't a Timken though. I returned it to napa and went somewhere else and got a Timken that did fit. It wasn't quite that small, but about .008 iirc.
Old 12-30-2014, 04:56 PM
williameub's Avatar
williameub
williameub is offline
I don't have the box anymore. Threw that away. But it did look legit. It had the little holographic anti-counterfeit badge thing.
Non of the parts houses around me carry Timken products... I might try ford.
Old 12-30-2014, 05:05 PM
Got4wd's Avatar
Got4wd
Got4wd is offline
I have heard from people that timken has gone to China. I haven't verfied this but if that's the case I will be looking for a new bearning mfg. Koyo has always been good.
Old 12-30-2014, 05:19 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
As I said, I had this same issue with both National and Timken bearings. I tried multiple of both brands and measured them, all were too small. Also verified the part numbers multiple times. I believe its more than likely a manufacturing flaw, but the fact that multiple brands have the same issues is what i couldn't figure out.
Old 12-30-2014, 06:50 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Bronco grave yard sells wheel bearing kits too. I wouldnt think they would steer you wrong. Have you guys tried spicer?
Old 12-30-2014, 07:08 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
That was one of the first places I looked. It seems JBG sells Timken Bearings as well...
Old 12-30-2014, 07:35 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Autozone here sells Timken bearings. I'm pretty sure they are still made in the USA. Timken is all I use. I have had issues with the inner bearing going up on the spindle before, but I just get it up there and push and keep wiggling the hub back and forth and they always go. Gotta hit it just right it seems like and they will slide right on there. It's almost always hard though.
Old 12-30-2014, 07:46 PM
quesey's Avatar
quesey
quesey is offline
Same thing here I used that little bit of space between the seal an race to hammer 1 on last week. Should be fun to get off someday.
Old 12-30-2014, 08:15 PM
DIYMechanic
I did bearings in a truck recently that were tight and I used heat to get them on. Heat the bearing up slightly (I just let it sit on the wood stove for a few minutes - not too hot or you'll cook the grease out of it) and chill the spindle (I stuck mine in the deep freeze for a while) and the little bit of difference it made allowed me to slip it right on.
Old 12-30-2014, 08:23 PM
williameub's Avatar
williameub
The bearings I took out where Timkens. They don't bind or seem tight at all. They slide right on with no play.
Old 12-30-2014, 08:29 PM
DIYMechanic
The spindle I was working with was less than perfect. Most should slip right on, but if they don't a slight heat difference should make it go without resorting to the BFH.
Old 12-30-2014, 08:31 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Just seems to be the way new bearings are. Like I said, about every time I've done them, which is more than I can count, the inner is hard to get on the spindle. You just gotta keep wobbling the hub around on there and pushing at the same time, and when it hits that sweet spot it will go on. it is frustrating, and I have had to stop and put the hub down and rest, then go at it again before, but it will go.
  #28
Old 12-30-2014, 09:12 PM
Bob_T's Avatar
Bob_T
Bob_T is offline
So after weeks of tracking down parts and waiting for them to arrive I started putting my front hubs back together.
I used Timken all around, and I've found the the inner bearing (387A) doesn't slide onto the spindle.
The diameter of the spindle is 2.25" at the bearing surface.
But the bore of my bearing measures 2.10".
Is the fifthteen thousandths due to the bearing being cold? It's only about 45*F around here.
What do you think?
Looking at your numbers, which I didn't the first time I read your post, you don't have a fifteen thousandths of an inch discrepancy, you have a difference of fifteen hundredths of an inch. That's more than an eighth of an inch. Something isn't adding up at all. Just wondering what kind of tool did you use to measure the bearing bore with?
Fifteen thousandths is too much for a press fit even if you heat the bearing and ice the shaft, but more than 1/8" is way out there.
Bob
  #29
Old 12-30-2014, 10:04 PM
williameub's Avatar
williameub
Originally Posted by Bob_T
Looking at your numbers, which I didn't the first time I read your post, you don't have a fifteen thousandths of an inch discrepancy, you have a difference of fifteen hundredths of an inch. That's more than an eighth of an inch. Something isn't adding up at all. Just wondering what kind of tool did you use to measure the bearing bore with? Fifteen thousandths is too much for a press fit even if you heat the bearing and ice the shaft, but more than 1/8" is way out there. Bob
Oops. My decimal place got off.
Spindle: 2.2531"
Bearing bore: 2.2369"
So a little more then a .015"
.0162" to be 'exact'. Id give or take half a thou or more with my digital calipers.
  #30
Old 12-31-2014, 08:16 AM
Bob_T's Avatar
Bob_T
Bob_T is offline
What do the old bearing bores measure with your digital calipers? I have a helluva time accurately measuring ID's with calipers. If you have a nearby machine shop maybe you could ask them to mike the bearing bores? Don't mean to be questioning your skills, it's just that calipers are not the best tool for measuring ID's.
7 Degrees F here outside of Reno this morning. That's cold for us!
Bob
scottddove
08-12-2015 12:48 AM
seaweaver
1999 to 2016 Super Duty
11-03-2010 07:17 PM
paddler
08-12-2010 02:36 PM
yotazuki
08-01-2009 09:46 AM
jimmeste
13
06-23-2008 08:46 PM
Quick Reply: Poor Tolerences on New Wheel Bearings?
