Poor Tolerences on New Wheel Bearings?
As I said, I had this same issue with both National and Timken bearings. I tried multiple of both brands and measured them, all were too small. Also verified the part numbers multiple times. I believe its more than likely a manufacturing flaw, but the fact that multiple brands have the same issues is what i couldn't figure out.
on
1 Post
Autozone here sells Timken bearings. I'm pretty sure they are still made in the USA. Timken is all I use. I have had issues with the inner bearing going up on the spindle before, but I just get it up there and push and keep wiggling the hub back and forth and they always go. Gotta hit it just right it seems like and they will slide right on there. It's almost always hard though.
Same thing here I used that little bit of space between the seal an race to hammer 1 on last week. Should be fun to get off someday.
I did bearings in a truck recently that were tight and I used heat to get them on. Heat the bearing up slightly (I just let it sit on the wood stove for a few minutes - not too hot or you'll cook the grease out of it) and chill the spindle (I stuck mine in the deep freeze for a while) and the little bit of difference it made allowed me to slip it right on.
on
1 Post
Just seems to be the way new bearings are. Like I said, about every time I've done them, which is more than I can count, the inner is hard to get on the spindle. You just gotta keep wobbling the hub around on there and pushing at the same time, and when it hits that sweet spot it will go on. it is frustrating, and I have had to stop and put the hub down and rest, then go at it again before, but it will go.
#28
So after weeks of tracking down parts and waiting for them to arrive I started putting my front hubs back together.
I used Timken all around, and I've found the the inner bearing (387A) doesn't slide onto the spindle.
The diameter of the spindle is 2.25" at the bearing surface.
But the bore of my bearing measures 2.10".
Is the fifthteen thousandths due to the bearing being cold? It's only about 45*F around here.
What do you think?
What do you think?
Fifteen thousandths is too much for a press fit even if you heat the bearing and ice the shaft, but more than 1/8" is way out there.
Bob
#29
Looking at your numbers, which I didn't the first time I read your post, you don't have a fifteen thousandths of an inch discrepancy, you have a difference of fifteen hundredths of an inch. That's more than an eighth of an inch. Something isn't adding up at all. Just wondering what kind of tool did you use to measure the bearing bore with? Fifteen thousandths is too much for a press fit even if you heat the bearing and ice the shaft, but more than 1/8" is way out there. Bob
Oops. My decimal place got off.
Spindle: 2.2531"
Bearing bore: 2.2369"
So a little more then a .015"
.0162" to be 'exact'. Id give or take half a thou or more with my digital calipers.
#30
7 Degrees F here outside of Reno this morning. That's cold for us!
Bob
