Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
1996 7.3 leaking diesel
Old 12-29-2014, 10:25 AM
cgolden9 cgolden9 is offline
cgolden9 is starting off with a positive reputation.
Hello. I need a little help. I just recently replaced my fuel lift pump on my 1996 F350 diesel. After about a day of driving with no problems, it started leaking from the valve stem looking thing on the fuel/water seperater. I went to the dealership and they said that little part is discontinued and that I would have to order the whole assembly for $400. Does anyone know of a cheap way to stop this leak? Or rig it to where it won't leak? It is not the part that the arrow is pointing to. It's the part below it that looks like a tire valve. Thanks
Old 12-29-2014, 10:44 AM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
Fuel Restriction Sensor. Common Leak.
Can either delete with plug or replace sensor, part number E8TZ-9S283-A.
Old 12-29-2014, 10:53 AM
rockop rockop is offline
rockop is starting off with a positive reputation.
I plugged mine.
Old 12-29-2014, 03:10 PM
bryanlindborg600's Avatar
bryanlindborg600 bryanlindborg600 is offline
bryanlindborg600 is gaining momentum as a positive member of FTE.
Its not the part the arrow is pointing too!! By your description it is leaking from the Schrader valve where you get fuel pressure readings manually, I would try to lightly snug it or pull it and wrap it with diesel rated tape and re install carefully!! You don't wanna crack the housing!
Old 12-29-2014, 03:29 PM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a good reputation on FTE.IDMooseMan has a good reputation on FTE.IDMooseMan has a good reputation on FTE.
IDMooseMan Craig Peters
That schrader valve is literally like the valve stem on your tires. Check the "push-pin" under the cap to verify it is properly tightened. If it is, do as bryanlindborgh600 suggested.
Unless the housing is cracked or the schrader valve is cross-threaded, there isn't much that would cause a leak there.
Edit:
Question to those that plug this item...How do you check your fuel pressure at idle to verify pressure is in spec (40-80 PSI)?
__________________
Craig "IDMooseMan" Peters - 1997 F-350 XLT 4x4 CCLB E4OD 4.10:1
VP BSU Veterans Club
, USAF SSgt 1983-1992
To those that have served, Thank You. To those that haven't served, You're Welcome.
How to Give REPS
Fraternal Order of Blue Max
Old 12-31-2014, 02:46 PM
540milotalon 540milotalon is offline
540milotalon is starting off with a positive reputation.
If the tape doesn't work and
/or the threads are damaged I would repair with an epoxy rated for fuel and drill (very carefully) and re tap.
__________________
'96 250 4x4 5 spd,Ext.cab, several mods
'95 350 2X4 5 spd, similar to above mods
'90-250 4x4 w/'93 7.3 IDI straight pipe K&N,
'89-250 4x4 7.3 IDI straight pipe K&N,300k+
'87-250 4x4 6.9 IDI w/Banks Turbo,GW 4 speed
'83F-350 2x4 6.9 IDI K&N, with 125k on 2/26/11
Old 01-01-2015, 09:28 AM
fordman67 fordman67 is online now
fordman67 has a good reputation on FTE.fordman67 has a good reputation on FTE.fordman67 has a good reputation on FTE.
If the valve part is leaking you can replace the inner core with one from a tire stem.they are the same.I doubt the leak is from where it goes in since that is npt thread. Just get a tire core removal tool and a valve stem from the parts store and you are set.no big deal.
Old 01-02-2015, 10:26 PM
lindstromjd's Avatar
lindstromjd lindstromjd is offline
lindstromjd is starting off with a positive reputation.
I used a tire stem valve as well. No more leaks for me. Literally the exact same thing.
__________________
FTE Arkansas chapter member
1994 F350 Crew cab dually
7.3 Powerstroke, ZF-5
Current mods: T500, Rosewood 160/30's, Hydro-boost, 120v IDM, 6637 intake
Mods in the works: Inter-cooler, 3" intake plenums, SD GTP38r, MarkFuga E-fuel
Old 01-03-2015, 09:54 AM
Always check the simple things first. How often we overlook that rule?
__________________
Old 01-03-2015, 02:40 PM
mapachoo mapachoo is offline
mapachoo is starting off with a positive reputation.
If you actually need the schrader valve diesel o rings is a forum sponsor and carries the part here's the number
#13-005 Schrader valve - Fuel Injection rated 1/8 MNPT
__________________
Eric:1997 SCLB F-250 4X4 4:10 ZF5
1947 ****** Jeep (usually broke)
1967 VW Beetle Daily driver
No man was ever wise by chance
Old 01-03-2015, 04:24 PM
Quote:
Isn't that the curse of learning how to work on vehicles? We always think it's something much more complicated than it is because we know how to fix those things, and just blow right past the super easy things because in our mind, "it can't be that simple..."
__________________
Similar Threads
So this happened last night Backwoods351 Ranger & B-Series 7 11-15-2014 02:00 AM
Ladies and Gentlemen I give you Dorman! wy4525 6.0L Power Stroke Diesel 35 11-14-2014 04:12 PM
I'm happy with my F-250 Aune163rd Modular V8 (4.6L, 5.4L) 0 11-09-2014 05:09 PM
1996 351 bronco coolant leak oldirtybronco 1978 - 1996 Big Bronco 2 04-07-2014 04:44 PM
This is interesting Jarryd 1987 - 1996 F150 & Larger F-Series Trucks 6 01-21-2014 11:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
