302 pulley system options?
Old 12-31-2014, 04:02 PM
barnfind 51's Avatar
barnfind 51
barnfind 51 is offline
This set is out of 89 Grand marquis. I am mocking up not to happy with the ac pump had to move out past the valve cover. Out in left field.on the left under ac pump is the smog pump area,on the right under the Alt. is the power steering pump,which I wont use.This set up uses two belts with a tension. Still would like to change the position of ac pump.Still is a lot cheaper than those real nice billet models.George
Old 12-31-2014, 10:53 PM
willymakeit's Avatar
willymakeit
willymakeit is offline
Where ever you go, get everything. I like Fords but they are a pain when it comes to pulliys and accs.
Old 01-02-2015, 12:04 PM
filthy6's Avatar
filthy6
filthy6 is offline
Interesting point about water pump rotation. How do I determine which direction the water pump was originally designed to turn? The engine is currently on an engine stand but the water pump doesn't turn either way because of drop. My friend felt responsible for the drop and bought me an aftermarket pump.
Old 01-02-2015, 12:31 PM
OK F1's Avatar
OK F1
OK F1 is offline
Check the timing cover
The easiest way is to determine rotation direction is to determine which timing cover you have...They need to match. Note the angle of the ports on the cover at bottom right.
You can probably Id the cover by part # (It is usually embossed at 6 O'clock relative to the water pump snout.
Old 01-03-2015, 11:33 AM
TireDood's Avatar
TireDood
TireDood is offline
Try www.cvfracing.com they have all sorts of pulley and bracket setups.
Old 01-03-2015, 05:08 PM
1LIFE's Avatar
1LIFE
1LIFE is offline
Let me know if interested.
https://www.ford-trucks.com/forums/1...l#post14963071
Good luck!
Old 01-03-2015, 11:15 PM
filthy6's Avatar
filthy6
filthy6 is offline
Good luck!
That sounds like a great offer. I think if I went that direction I would go with power steering. Still wobbling around in my mind. Good luck.
AbandonedBronco
08-09-2019 11:50 AM
old_dan
01-12-2015 07:25 AM
Godlover
10-17-2012 05:35 PM
special 55
03-02-2011 07:47 AM
30dodge
08-07-2009 05:38 AM
Quick Reply: 302 pulley system options?
