2008 f250 powerstroke
Good question, I am also curious.
Unfortunately, even if it is the same radiator, the diesel cooling system is different, and the truck is heavier, so there is more than 1 difference to blame the problem on.
Lots of trucks do not have that issue, and some of the 2011+ also have a problem with radiators.
My 2008 never had an issue, and I have another 2008 which has 277,000 which I assume is the original, since it only has single o-rings on the fittings.
Chances are if your going through radiators that fast, something else is going on.
Any ideas what it could be. Everytime we replace it, we replace everything as required by the TSB's. The last 2 times it went out we drove up a mountain to go snowboarding, the 3 times before we towed a 3500lb boat. I don't feel that these are extreme hauls. Got this truck for the horses and I use my Tahoe Hybrid to tow them. Doesn't make any sense. Help
We designed an aluminum radiator which has proven to be an effective replacement for a high majority of our customers. That being said, we still have a small sample of customers who are continuing to experience failures even after switching to the Mishimoto unit. We are working on several different prototype designs which work to better isolate the radiator from the core support which should reduce the impact of chassis flex. Our prototype units have been installed in test vehicles and we are evaluating the success. Once we get a bit closer to a final design or conclusion regarding our tests, we will certainly update the forum.
Feel free to follow-up with any questions about the 6.4L radiator!
Thanks
-John
Great question. The issue does not seem nearly as prevalent in the gasoline version of this truck.
I don't know how to make it part of my profile, but this is the specs of the truck...
2008 F250 Diesel Super Duty Crew Cab
6" lift tires are 20/37.
Picking up the truck today. I will let everyone know the results of the new radiator.
There is a cross bar of some sort on the front underside of the truck. I will take a picture of the underside.
Like from roughly the points at which the radiator mounts.
That should get rid of any flex that is killing the radiator.
But install the bars behind the radiator where theres lots of room
I believe some people don't know about flexing the frame, or what happens to cause the frame to flex until it's too late. The road I live on has a steep hill right at the beginning as you turn on it. So the right tire starts to raise at a considerable rate before the front starts to go up. I broke 3 automatic transmission housings in a GMC service truck I had years ago before I realized what was causing the problem. I have replaced the radiator in my 08 a few months ago. But, since the tranny problem in the GMC, I have learned to swing wide when making the turn. But, I do find myself in certain situations with my service truck that can cause the frame to twist. So, with that in mind as being a possible cause for radiator failure, I will look for those situations and avoid them when possible.
#28
With cable, it might be trickier.
Tightening up the front end, would limit the amount of front end flex around the radiator.
#29
#30
Thanks!
Thanks
-John
