Starter question
Starter question
My daughter came home from school and last week she called me from a parking lot and said the truck would not start. 1975 ford f100 302 automatic. I tested the post from the solenoid to the starter. I got a 0 reading. I then disconnected the starter and with the key in start, I had 12. something. I took the starter to be tested and it was bad so I replaced it. Autozone. It ran fine for a few days. Today she went to start it and no go. It seems like it wants to spin, but is very slow. I put a power pack on it and still nothing. I check the voltage the the positive post to the starter but was unable to get a reading as it is digital and it is all over the board. I did notice that both the positive posts are hot in temperature. Should I take the wire off the starter and check it again? Or should I be looking at something else?
It wouldn't hurt to have the battery checked too.
Yep. If the cables are hot that generally means loose, or corroded connections. On a 73 just replace them being 40 years old and wire-wizz or file away any paint or corrosion at the block and frame away to clean down to bare shiny metal. There's three main ground cables or straps, maybe $20 total.
The older trucks always have corrosion problems. Even new trucks just a few years old. It pays to take an afternoon going over all the connections. On restored trucks the problem isn't corrosion but everything gets painted over and can cause a lot of headscratching.
It is most likely a defective new starter since it worked fine for a couple of days then quit. Had it happen to me a few months ago. Auto part stores seem to sell a lot of junk lately. I would think you checked, cleaned and tightened all of the electrical connections during the first starter troubleshoot/replacement.
Use your voltmeter across the negative post and starter case to measure voltage drop during cranking. Also test positive side cable at starter post and battery. Should be no more than a couple tenths of a volt. The current is obviously being soaked either by cables/connections, or a bum starter. Put the battery on a slow amp charge overnight since it's been thrashed pretty hard.
So far I brought the one week old starter back to Auto Zone and had it tested. It failed. They do not have a replacement starter. I have called around an nobody has one. They have all ordered one for me and I will take the first that arrives. I want the better model. I have called Auto Zone, Advance and CAP. CAPs better one is 50.00 wheras the other two have "better ones" at 95.00. Ho could there be such a difference in the "better one" price? Any thoughts?
Here is what it takes to rebuild a starter...
Scroll through the slide show for the play-by-play...Mump 0912 01 O+1965 Ford Mustang Starter+starter - Photo 31293063 - 1965 Ford Mustang Starter Rebuilt - Mustang Monthly Magazine
Alternatively, it's YouTube to the rescue:
Part 1:
Part 2:
Here's the $16 kit you should order:
Part 1:
I agree with you guys assessment of the rebuilders these days. Especially, A Cardone.
Have a feeling that most throw in new gaskets /o rings and clean them up then send them out.
I would much rather pay a local rebuilder (in other words....having a guy) to rebuild MY starter/alt/whatever.
Have bought way to much garbage lately.
Good luck with your starter.
