1973 Ford f100 Popping
Have a 1973 f100 with a FE 360 that was popping threw the carb when we got it, so we had the carb rebuilt and it still does it. We replaced the spark plugs and did a compression test and all cylinders came back with 130lbs each. Also replaced the points, condenser, cap and rotor
Any ideas on what it could be.
I was wondering about that. Any chance the timing chain has jumped a tooth or two? Backfiring through the carb is pretty much always a timing issue.
Make sure the plug wires are routed correctly and firing order is correct. This is a good thing to check (among others) when getting a "new" truck.
"Only" 145,000 miles? It could be 245,000 or 345,000 since the odometer rolls over at 99,999.9 and goes back to zeros.
Unlike today's highly engineered/machined components with close tolerances and electronic engine control systems, engines in vehicles of this era typically require a rebuild at 100K miles.
Bad, cross firing plug wires could be the culprit also a bad coil. Like others said, there seems to have been a bad bunch of condensers popping up lately.
The compression test you did pretty much rules out a stuck valve.
From your description it could be fuel related also. You said that it falls on it's face when you accelerate and that's also when it pops. Check the accelerator pump, be sure that it's functioning. Pull the air cleaner cover off and look down the throat of the carb. Push the accelerator, you should see two strong squirts of fuel into the throat of the carb.
