Installing HD alternator in 95 F350/460
You might try:
Colaw RV Parts & Salvage 10389 Cimarron Rd. Carthage, MO 64836 (417)548-2125 Email: Colaw RV Used Parts - We Have Your Part...
No that's not necessarily true. To the best of my knowledge only the small case 95amp alternator was available as standard and the large case 130amp was not available on the F350's.
It was on some of the vans but rarely. Im looking for the 460 bracket that mounts from the engine to the alternator top which is different than the stock 95 amp bracket in order to mount the larger alternator.
An upgrade to a 3G alternator is a very popular upgrade to our trucks and an easy and safe way to get a 130 amp alternator. Do a search here in the forums. There are lots of threads and lots of links in those threads to some good info. I did mine not too long ago and I am very pleased with the results.
Here is all the info I have on the 3G alternator, but there is LOTS more out there.
http://store.alternatorparts.com/3gl...smallcase.aspx
Ford Alternator and A/C Clutch Repair Connector - The Repair Connector Store
Alternator Harness for Ford 3G-Ron Francis Wiring
https://www.ford-trucks.com/forums/1...lternator.html
https://www.ford-trucks.com/forums/1...-newer-3g.html
https://www.ford-trucks.com/forums/1...emergency.html
3G Altenator - Page 4 - Ford F150 Forum - Community of Ford Truck Fans
https://www.ford-trucks.com/forums/1...quesitons.html
Crazed 3G install (56k be very aware) - FSB Forums
FSB Forums - View Single Post - 3G Interchange Facts. If you're thinking 3G read here.
3G is the third generation alternator design referred to as a AC Generator on Ford wiring diagrams.
The one you all ready have on your 1995 F350 truck is a 3G alternator.
Also note that the 130 amp alternator for the 1995 460 on a F53 is a swing belt adjustment alternator.
To tell a 90/95amp alternator from a 139 amp alternator look at the front of the alternator.
You will see 3 pairs of ribs.
If there are four holes between the ribs it is a 90/95A
If there are two holes between the pairs of ribs it is 130A
The 90A case is 135mm in diameter
The 130A is 148mm in diameter
It will bolt right on, though you probably want to upgrade the charge and ground cables.
I have a 130A 3G retrofit on my 460 from DB Electrical.
DB Electrical - ALTERNATOR FORD F SERIES TRUCK 4.9L 94 95 96 / 7.5L 95 96 97
They sell a 200A as well, but I wonder if the serpentine belt has enough traction to drive it at that amperage.
Edit to add Ebay pic.
Stock in trucks was the four hole 95A variety.
http://www.ebay.com/itm/NEW-ALTERNAT...cb07ca&vxp=mtr
Did you have to change brackets to go from 95 to 130 amp with a stock dimensions alternators?
My '87 is swing adjustment with V-belt pulleys.
It came with a 60A 2G.
I had to put a thin shim washer behind my pulley to keep it from rubbing the case, and tap the adjuster bolt hole from 8x1.25 to 3/8-16"
It is the 8 1/4" C-C mount as used on the Taurus/Sable/Windstar/Lincoln 3.8 V6.
It fit the stock arm and pivot just fine.
Even used the same belt.
Everything lined right up.
(edited out irrelevant question)
The 460 and 4.9 list the same Lester number for application.
I think the OP is misinformed.
The dimensions of the upper pivot are the same.
Using the 8.25" ear mount pushes the larger diameter case out for the required clearance.
If it didn't fit, the number would not be the same.
