4r70w pan drain and refill
I dropped my pan to replace my tcc solenoid and filter. I had heard or read or saw somewhere where the pan is about half the total 13+ qts of mercon V. Well I filled it up with 6 qts before checking and the fluid is up on the "do not add" area. I cranked and let it run to op temp and shifted through all gears a few times. The level is still up there. Should I loosen the pan and let the fluid drain out level with the top of pan or would it be better to take loose the cooler line up front and flush out a couple or few quarts and top off as necessary?
I think there is a long suction tube & pump at auto parts store you can get to to pump some out through the fill tube. don't ask where I saw that. Phone around to your favorite parts store and ask if they got such a thing. If you can find it it might save you from a big mess
I'd be inclined to take a short drive...see that it shifts and then recheck the level. If it is still high then prolly pull the cooler line and drain some out.
jeffreyt
357
01-30-2022 11:28 AM
Gatordog
10-11-2015 10:35 PM
phroman
03-04-2007 11:49 AM
blownbronco
15
01-12-2003 08:19 PM
