A few more 7.3 PSD questions
Hello again, everyone.
I had up a thread previously trying to determine the cause of the rough idle I had been having. I have new Valve Cover gaskets, and a new ICP, along with a CPS that's going to go in the glove box as a spare. I was wondering two last things-
I picked up 8 new glow plugs to swap in since I'm gonna have the covers pulled anyway. Should they be fitting loosely in the connectors to the gaskets? They aren't seeming to be in danger of just vibrating off, but they seem to be very loose. Is this normal?
Also, should I use RTV/liquid gasket on my valve covers, or could that interfere somehow with the electrical connections?
Thank you.
Thank you.
I bought motorcraft plugs from a local store. Next question is should I use dialectric grease or anything on the connections, or would that benefit me at all?
Also, does the HPOP take the same oil as the engine, or should I be adding some sort of special lubricant to the reservoir?
I'm pretty new to the 7.3...
I bought my 7.3 in March so I'm pretty new also. I'm having a great time slowly but surely getting my truck in shape. This forum is full of information and when I have time I read through it. Just about everything I know about the 7.3, and I don't know much compared to most of the members here, came from the threads here.
The HPOP uses the same oil as the engine. It is supplied with oil from the engine's crankshaft driven oil pump. Anything we might put in the HPOP ends up back in the crankcase, so no special oils.
Did you use the same oil and same viscosity as always when you changed it? I think oil that is too thin doesn't work well with the injectors. You could try draining your oil into a clean bucket and adding new oil. If it still runs rough then Lucas isn't the problem and you can save the oil that's contaminated with Lucas additive for your next oil change.
Bob
I have not nor would I ever put any additive in my PSD.
I have no experience having thus additives but have always seen opinions against them in these engines . the viscosity is very important to make the injectors function correctly.Lucas oil additive makes the oil cling much more than normal oil.I would not want that knowing how these operate.that may not be your issue but if it were me I wouldn't want that variable involved in this equation.
on
1 Post
Thomas Young
1999 to 2016 Super Duty
02-05-2017 07:43 PM
crstewart60
12-26-2011 06:23 PM
