Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-23-2014, 11:44 PM
wils3825's Avatar
wils3825 wils3825 is offline
wils3825 is starting off with a positive reputation.
A few more 7.3 PSD questions
Hello again, everyone.
I had up a thread previously trying to determine the cause of the rough idle I had been having. I have new Valve Cover gaskets, and a new ICP, along with a CPS that's going to go in the glove box as a spare. I was wondering two last things-
I picked up 8 new glow plugs to swap in since I'm gonna have the covers pulled anyway. Should they be fitting loosely in the connectors to the gaskets? They aren't seeming to be in danger of just vibrating off, but they seem to be very loose. Is this normal?
Also, should I use RTV/liquid gasket on my valve covers, or could that interfere somehow with the electrical connections?
Thank you.
Old 12-24-2014, 12:34 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE is gaining momentum as a positive member of FTE.
#1. What kind of gp's did you get.
The connector shouldn't be loose. You should have to give a light tug to get it off and no sealant or gasket maker on the valve over gaskets.
__________________
It's hard to soar like an eagle when your flying with a bunch of turkey's
1997 F-350 xlt cclb PSD 4x4 zf5
1989 F-350 4x4 7.3 c6 auto retired
2000 F-150 XLT 4x4 4.6 e4od
Nick
Old 12-24-2014, 10:17 AM
Fordman96 Fordman96 is offline
Fordman96 is gaining momentum as a positive member of FTE.Fordman96 is gaining momentum as a positive member of FTE.
^^^ you shouldn't have to use sealant. If you read the gasket it should have "reusable gasket" printed on it so it's built to last.
I remember when I did my GPs I had a heck of a time taking off a few of the GP connectors.
__________________
Zack
1996 Bronco 351W 307k original 4.10s
2002 Excursion Limited, v10, 220k
1997 F350 CCLB 127k miles 4.10s 7.3 PSD
Old 12-24-2014, 04:48 PM
wils3825's Avatar
I bought motorcraft plugs from a local store. Next question is should I use dialectric grease or anything on the connections, or would that benefit me at all?
Also, does the HPOP take the same oil as the engine, or should I be adding some sort of special lubricant to the reservoir?
I'm pretty new to the 7.3...
Old 12-24-2014, 05:16 PM
Bob_T Bob_T is offline
Bob_T is starting off with a positive reputation.
I bought my 7.3 in March so I'm pretty new also. I'm having a great time slowly but surely getting my truck in shape. This forum is full of information and when I have time I read through it. Just about everything I know about the 7.3, and I don't know much compared to most of the members here, came from the threads here.
The HPOP uses the same oil as the engine. It is supplied with oil from the engine's crankshaft driven oil pump. Anything we might put in the HPOP ends up back in the crankcase, so no special oils.
__________________
'96 F250 Longbed 7.3L 4WD 4.10 Gears Auto
Old 12-24-2014, 05:27 PM
wils3825's Avatar
Perfect, thank you.
Old Today, 04:06 PM
WDNewcomb WDNewcomb is offline
WDNewcomb is starting off with a positive reputation.
I changed oil and filter And put Lucas oil additive in oil, engine running rough now, Is Lucas the cause? What else?
Old Today, 05:49 PM
Quote:
Hope I don't start something that I can't finish. I don't know if Lucas is the problem, but I do know that tests of various Diesel fuel additives show that Lucas Diesel fuel additive is worse than no additive at all as a fuel additive. Lucas motorcycle oil ends up at the bottom of motorcycle oil tests too. Don't know where that puts Lucas oil additive. My opinion on Lucas in general is that they spend huge amounts of money sponsoring racing, which is a very good thing for racing and it also sells Lucas products. But their ad budget dominates their expenses and not enough money goes into their products. Of course some people swear by Lucas, the above is just my opinion.
Did you use the same oil and same viscosity as always when you changed it? I think oil that is too thin doesn't work well with the injectors. You could try draining your oil into a clean bucket and adding new oil. If it still runs rough then Lucas isn't the problem and you can save the oil that's contaminated with Lucas additive for your next oil change.
Bob
__________________
Old Today, 06:00 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to all
Powerstokes are completely different motors with high pressure oil to run the injectors. If any foaming at all occurs then get that stuff out of the motor. If it has anti-foaming agents added, then I don't know.
__________________
Glenn The Mule-96 2WD F250 EC/LB auto PSD
The Mare 97 dually cc,modified s366 turbo,stage II's,IC,studs,springs,rods,JW auto,4:10 LS,air bags,SD uvch,efuel,FS2500 bypass oil filter,HVHF IDM,IH WP,6.0 trans cooler & rad fan,MBRP 4",SD tensioner,AFE air filter,220 amp alt,38 gal rear tank & 33 gal aux bed tank,aux oil cooler,soundproofed,3 different TS chips,ac cold mod,XS batteries,riffraff hpop reservoir,aluminum radiator,HoneyBadgerJr hpop, water injection
Old Today, 06:00 PM
Similar Threads
thoughts on using RTV with a gasket granny_rocket 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 10-23-2013 11:47 PM
Stuck valve covers / GP removal fleetsidebob 1994.5 - 1997 7.3L Power Stroke Diesel 21 01-24-2012 10:49 PM
valve cover gaskets mybigredford 1999 - 2003 7.3L Power Stroke Diesel 6 01-23-2008 11:33 PM
Replaced some gaskets on the 300... cryptonik420 Ford Inline Six, 200, 250, 4.9L / 300 4 11-12-2003 07:50 AM
valve cover gasket? Martys82 Ford Inline Six, 200, 250, 4.9L / 300 8 04-06-2003 03:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
