General Diesel Discussion
Can I fill my old home heating oil tank with on-road diesel?
Old 12-23-2014, 08:48 PM
lemonshindig's Avatar
lemonshindig
lemonshindig is offline
I am almost done converting from an oil furnace to an air source heat pump.
I still have an underground 500 gallon oil tank that is darn near empty. With the recent price drop in diesel, I would LOVE to top that tank off with on-road taxed ULSD. Then when the price goes back up, I'm saving money.
Has anyone done this?
Thanks
-Matt
Old 12-23-2014, 11:01 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
We use several old fuel oil barrels for gas but they are above ground tanks and cleaned well, a buried tank will be very hard to remove the last little bit of fuel oil and clean. If your daring you could remove all the old oil you can and fill, then use very good filters but I guarantee it will be dark looking fuel the first few tank fulls.
Old 12-23-2014, 11:19 PM
87crownvic2door's Avatar
87crownvic2door
87crownvic2door is offline
why pay taxes on fuel when you don't have to , buy home heating oil that's not taxed by uncle sam
Old 12-23-2014, 11:24 PM
87crownvic2door
better off using off rd fuel its died red[ farm tractors , construction equipment fuel]heating oil no. 2 diesel, why pay for rd tax if you don't have too, plan on driving your house on the interstate
Old 12-23-2014, 11:27 PM
87crownvic2door
same stuff but cost over a $1.oo more per gallon rd fuel pays rd tax
Old 12-23-2014, 11:30 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
In theory that's a great idea. But there's some things to be done to make sure it's OK as far as contamination, algae, etc. The people who filled the fuel oil tank may have the skinny on that.
Old 12-24-2014, 07:45 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,102 Likes on 2,164 Posts
yes it can be done. get a suction pump that will reach down to the bottom of the tank, and suck it out, filtering what is in there to get as much crud out of the tank as you can.
then you can put the filtered fuel you took out back in and top it off.
set your pickup from the transfer pump 1-2 inches off the bottom of the tank, and send it through a water separator/filter before the pump.
not sure what algae conditions are in Washington, but here in New Jersey i still have about 100 gallons of 13 year old fuel left in my tank i use in the 88 in the winter.
once i get rid of the high sulfur fuel in the tank i will be filling it up with ULSD for use in all the diesel trucks.
Old 12-24-2014, 02:46 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
Re-read his post, his plan is to stock up on cheap fuel for his trucks so that when it goes back up he will be money ahead.
Old 12-24-2014, 07:16 PM
lemonshindig
I'm not interested in avoiding fuel tax. We who use the roads ought to be paying our fair share.
Thanks for the thoughts, guys.
Old 12-24-2014, 08:23 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Avoiding is fine. Evading, not so much.
Old 01-18-2015, 07:51 PM
parkland's Avatar
parkland
parkland is offline
Large empty tanks tend to build a fair share of moisture.
By the time you mess around and buy pumps and filters, do you really save much?
Especially considering this is a 1 shot deal?
Old 01-19-2015, 12:33 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Why is it a one shot deal, though? Doesn't have to be. It would be nice to have a big ole slug of fuel on hand too.
Old 01-19-2015, 06:33 AM
tempforce's Avatar
tempforce
tempforce is offline
go for it, just use a 10 micron filter/separator before or after your transfer pump.
I've used a small 250 gallon fuel oil tank for years... for both the truck and tractor... if your afraid of algae, put in some biocide.
I'm using a cheap 1" water pump as my transfer pump.
a pressure relief valve is on my discharge side of the pump/filter, returning extra fuel back to the storage tank, when my nozzle is not open/filling the vehicle.
Old 01-22-2015, 07:51 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is online now
I think its a great idea. I wish I had the tank to do the same thing
Old 01-26-2015, 11:27 AM
tempforce's Avatar
tempforce
lots of people are getting rid of oil and propane tanks. just look for a nice clean one.. and make it into your storage tank. caution if you convert the propane tank. ensure the tank is filled with water when you cut or weld to install fittings.
Quick Reply: Can I fill my old home heating oil tank with on-road diesel?
